GPU not showing up on apps setting
bullrees
I'm not sure wht to think here. There are multiple topics on this with no real answers. Am I wasting my time on TRUENAS?, Is this a known thing or is this a minority thing that is disregarded?
richard_rama
Same Issue here, Being able to see the gpu on the GPU isolation menu but nvidia-smi fails.
root@truenas[/home/admin]# nvidia-smi
NVIDIA-SMI has failed because it couldn't communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.
Any clue? thanks!
richard_rama
Sorry to answer that fast but i´ve goot this from the console
huizingajm
I have the exact issue of GPU showing the same above errors. HoneyBadger in the Discord help me resolve the issue of nvdia.smi not showing anything. Now my GPU shows up in Plex Plugin settings. However inside of the Plex settings itself it does not show up.
My audio skips like crazy when transcoding 4k HEVC to 1080p. I setup a test Plex server on my Desktop and tested the same file playing to the same device and it plays just fine transcoding.
HoneyBadger
actually does care
Administrator
I thought I heard my name.
I'm not a Plex user, but searching around seems like it might be related to the audio codec being used; I see mentions of passthrough audio causing this as well. Can't say much on this front I'm afraid.
But the tl;dr for resolving the nvidia-smi problem (not mapping to GPU) was a stuck passthrough driver claiming the card - check this post here for details on how to verify if you're facing this issue, and how to resolve it:
Saberwolf
@bullrees i am pulling your and trying to help you because i use a p2000 also and i have no issues but i set mine up a little different. let me explain i have hardware transcoding work and available to more than one app at a time. you will need to set ENV Variables in the app PIC coming.
what we are doing it not using web ui to allocate gpu recourses we are passing those through ENV Variables. take a look at the website it helps explain my settings and my choices.
if you add Nvidia visible devices and its capabilities you will get Hardware transcoding working as long as there are not issues on the host machine. refer to the above web link for all Available options for variables i simplify mine by use all gpus and all available driver capabilities
What this does is allow you to use your single gpu for more than on app oh i forgot to tell you you need to in the Web UI remove the GPU from the app
this setup works and has no issues on any version that has come out. plus you can have more than one app use one gpu for transcoding. just to let you know you have to be on the host CLI and run Nvidia-SMI to see gpu usage due to permissions you can not be in the container and run nvidia-smi it will report nothing other than it is there.
sos_nz
Nope didn't work for me...I removed the graphics card as per your second picture (Allocate 0. nvidia.com/gpu GPU), restarted the app, then entered the environmental variables you've shown.
Got the error message:
"[EFAULT] Failed to update App: Container - Environment Variable [NVIDIA_DRIVER_CAPABILITIES] in [envList] tried to override the Environment Variable that is already defined in [fixedEnv]"
Luckily for me my Jellyfin Truecharts app works when I 'Allocate 1 nvidia.com/gpu GPU' under GPU configuration, so I was just trying this for funsies.
Saberwolf
Luckily for me my Jellyfin Truecharts app works when I 'Allocate 1 nvidia.com/gpu GPU' undder GPU configuration, so I was just trying this for funsies.
Like I stated before the gpu needs to be removed from all apps the fix is in your error just remove driver capabilities and use the rest every docker container has some pre defined env variables research your error and try again. It is just stating your trying to define variables twice.
sos_nz
Yes, I figured that to be the case. The only app I have which was using the GPU was Jellyfin, and I removed it for that.
None of my VM's use the GPU (not that they can, since I only have the single 1060 and I want that for hardware transcoding in Jellyfin, so it's not isolated either).
So: the error message occurred despite the GPU being removed from all apps.
EDIT: It worked! For those a bit slow like me, I removed "Enable GPU Support" under Apps > Settings > Advanced Settings, and had "Allocate 0 nvidia.com/GPU" under the app's GPU configuration. Not sure if removing GPU support is needed under the advanced settings is needed or desirable.
flammen
For me it fixed itself in one of the latest updates. I am running TrueNAS-SCALE-23.10.0.1 now. RTX2060 super. Jellyfin Official App Version 10.8.13. I do not know how and when it happened.
flammen
And it does not work again. Something broke it again. I did not change any hardware, I did not even reboot the machine.
Truenas is still on 23.10.0.1
Jellyfin 10.8.13 chart version 1.2.3
Why does Jellyfin randomly break GPU support on updates?
calholl
For me (i7 12700k + Asus w680) it only works if I have a monitor plugged in at the time the computer boots up. Tried updating bios and going in and turning on the CPU multi-monitor option but neither had an effect. Only thing that seems to work is booting with monitor attached. How weird.
azanutta
Thank you for reporting this.
I am trying to setup the FRIGATE app in TRUESNAS SCALE however even with your suggestions,
{ "Enable GPU Support" OFF and https://jamieede.com/posts/truenas-scale-multiple-gpu-assignment/ suggestions already found in this link }
I am getting the same error:
[EFAULT] Failed to update App: WARNING: Kubernetes configuration file is group-readable. This is insecure. Location: /etc/rancher/k3s/k3s.yaml Error: UPGRADE FAILED: execution error at (frigate/templates/common.yaml:11:4): Container - Environment Variable [NVIDIA_DRIVER_CAPABILITIES] in [envList] tried to override the Environment Variable that is already defined in [fixedEnv]
more in detail:
File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 187, in nf
  File "/usr/lib/python3/dist-packages/middlewared/plugins/chart_releases_linux/chart_release.py", line 567, in do_update
    await self.middleware.call('chart.release.helm_action', chart_release, chart_path, config, 'update')
  File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1564, in call
    return await self._call(
  File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1428, in _call
  File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1321, in run_in_executor
  File "/usr/lib/python3.11/concurrent/futures/thread.py", line 58, in run
  File "/usr/lib/python3/dist-packages/middlewared/plugins/chart_releases_linux/helm.py", line 49, in helm_action
    raise CallError(f'Failed to {tn_action} App: {errmsg}')
middlewared.service_exception.CallError: [EFAULT] Failed to update App: WARNING: Kubernetes configuration file is group-readable. This is insecure. Location: /etc/rancher/k3s/k3s.yaml
could be due to THIS problem?
