GEOM_ELI Error
M.A
I'm running a fresh install of FreeNAS-9.3-STABLE-201503270027 and I just got a weird warning in the log. The pool is still online though and the status indicator in the web-gui is still green!
Hints please?
[root@NAS] /mnt/tanky# tail -f /var/log/messages
Apr 13 15:16:46 NAS kernel: mfisyspd0: hard error cmd=write 6504096-6504143
Apr 13 15:16:46 NAS kernel: GEOM_ELI: Crypto WRITE request failed (error=5). gptid/06bc5d30-e1d1-11e4-b7d6-1c6f653f0b50.eli[WRITE(offset=1182547968, length=24576)]
Apr 13 15:16:53 NAS kernel: mfi0: I/O error, cmd=0xffffff8000a9c660, status=0x2d, scsi_status=0x2
Apr 13 15:16:53 NAS kernel: mfi0: sense error 114, sense_key 1, asc 0, ascq 0
Apr 13 15:16:53 NAS kernel: mfisyspd0: hard error cmd=read 7814036624-7814036639
Apr 13 15:16:53 NAS kernel: GEOM_ELI: g_eli_read_done() failed gptid/06bc5d30-e1d1-11e4-b7d6-1c6f653f0b50.eli[READ(offset=3998639202304, length=8192)]
Apr 13 15:17:00 NAS kernel: mfi0: I/O error, cmd=0xffffff8000a9c330, status=0x2d, scsi_status=0x2
Apr 13 15:17:00 NAS kernel: mfi0: sense error 112, sense_key 5, asc 33, ascq 0
Apr 13 15:17:00 NAS kernel: mfisyspd0: hard error cmd=write 6505520-6505575
Apr 13 15:17:00 NAS kernel: GEOM_ELI: Crypto WRITE request failed (error=5). gptid/06bc5d30-e1d1-11e4-b7d6-1c6f653f0b50.eli[WRITE(offset=1183277056, length=28672)]
FreeNAS 9.3 Stable
SanDisk 32GB SSD (FreeNAS Disk)
7 X 4TB of WD RED drives (RAIDZ2)
IBM ServeRAID M1015
i7 @ 3.6 GHz
GB GA-X58A-UD3R
16GB DDR III RAM
Cheers
mfi0 implies you are using hardware RAID. So not unexpectedly, things are not working properly. My advice would be to backup your data NOW if you don't already have a backup. You may have to rely on that backup before you finish correcting the issue.
In the mean time, a debug file (system -> advanced -> Save Debug) would be very useful.
M.A
@ cyberjock
You are correct about RAID mode. An hour ago I flashed the card with IT firmware. Rebooted the machine and recreated the pool. Still got GEOM_ELI warnings but this time the GUI showed my drives are -1. It ended up being a bad power plug!
Thank you guys for responding
Cheers
I would recommend you do a badblocks and SMART short, long, and conveyance test just to rule out the disks from being bad.
Glad you didn't lose data. Usually the next conversation after errors like that is "why won't my pool mount, can I just get my data off?" and things go exceedingly bad at that point. ;)
M.A
OK. Will run these tomorrow. I have had enough with it for today :). I'm double backed up BTW, but thanks for the advice guys!
Cheers
