 - May 18, 2016
Warning:  Yes this theme is very definitely less than stable and may have breakage or other oddness from time to time, and its entirely possible that not everything will be easy to accomplish when using it.  I'll try to fix/revert the worst problems as soon as I notice them but zero guarantees.  Only one hue until work is complete.
Take a peek at Ganz großes Kino -testing things and see how it works. I think that the "stepped" responsiveness (via subset of defined viewport/media sizes) causes some adjustments that may remove control from the general adjustments I am using in my EXTRA.css file. Possibly if I use similar width definitions in each media section the flaws will iron out. It is something to investigate further. However,
for many possible widths:
- default font sizes and line heights for 'html' and 'body' use the adaptive units
 - the editor is more properly sized (ie, matches usable space much nicer)
 - message avatar/user info boxes (left side of each post) resize more appropriately, including the avatar and content text
 - the "online" ribbon resizes nicer
 - There is definitely fallout all over the place caused by the adaptive unit stuff.
