FTP Login Recording
mgswed
I have setup FTP and it is working as intended, but it is recording every successful login. I have several cameras logging in every second and uploading images. How can I only allow it to record unsuccessful logins. Its a home network with no access to the outside. Thanks.
mgswed
No one has any suggestion. My /var/log directory is getting filled up by so many ftp logins. Is there a way to only log unsuccessful logins. The result of this causes a root email every five minutes to be sent because the directory is full.
I got nothing. :/
lpittman
It is just proftpd - do a google search for how to configure it. :)
warri
In the Auxiliary parameters input field you can extend the proftp configuration via the GUI (Services - FTP - Advanced).
Just add extended logging like described here: http://www.proftpd.de/HowTo-Logging.31.0.html
You can specify any output file for the log, also on your persistent storage.
