I'm running my server through the paces and noticed that I'm seeing considerably slower FTP transfer speeds than when using the share mounted via CIFS. This is a local network connection and I've been able to consistently reproduce the results. Transferring files concurrently doesn't appear to affect performance either. I'm testing 1-6 gig video files.
Most of the reading I've done indicates others have experienced the opposite, fast FTP and slow CIFS, or an entirely different issue related to upload/download speeds. Any suggestions on identifying why FTP would be so slow?
Server Specs:
CPU: 2x Intel Xeon E5-2620 V1 Hex (6) Core 2.0Ghz
RAM: 32GB DDR3 (8 x 4GB - DDR3 - ECC REG)
HBA Controller: QTY 2x LSI 9210-8i 8 port HBA controllers updated to ITMODE for JBOD
NIC: Integrated Onboard 4x 1GB Ethernet Ports
OS: FREENAS 11
Supermicro 2U 12x 3.5" Drive Bays System
Server Chassis/ Case: Supermicro CSE-826A-R1200LPB
Motherboard: Supermicro X9DRi-LN4F+
Backplane: BPN-SAS-826A I-Path Direct Attached Backplane
PCI-Expansions slots: Low Profile 4 x16 PCI-E 3.0, 1 x8 PCI-E 3.0, 1 x4 PCI-E 3.0 (in x8)
* Integrated Quad Intel 1000BASE-T Ports
* IPMI 2.0 Compliant
2x 920Watt Power Supply PWS-920P-1R Platium
Server Specs:
OS: FREENAS 11
