FreeNAS11 with Plex and NIC Problem
vikozo6
Hello
I have a question about Plex and Jail.
I go to the Jail plexmediaserver_1 and to edit to add a Fix IP, i will have also to select a NIC but there is nothing to select.
If i press save it close but it stay in the Basic Mode, again to Press Save just nothing happen.
If then i reopen the advanced mode where the nic is, is a error
Select a valid choice. epair1b is not one of the available choices.
what does it mean?
have a nice day
vinc
D
dlavigne
Guest
Which build version of FreeNAS (System -> Information)? Is this while logged into the old UI or the new UI?
vikozo6
FreeNAS-11.1-RELEASE (also 11.0) and the OLD Classic UI
Are you attempting to do this with the jail running? If so stop the jail first, make the changes and then start the jail back up. In FreeNAS 9 you could do it while active in FreeNAS 11 old UI it needs to be stopped first.
