therealpure
- Jan 6, 2014
UPDATE:
After re-flashing the USB stick I was able to recover to 11.2. I then restored the configuration and can see my files and pool, etc. What does seem to be missing is a jail. Do jails not get recovered?
I have a HP Proliant server box with 16 GB RAM, 4 HDD and a USB stick with Freenas OS on.
This has been working well for me for sometime. I tried to upgrade to 11.3 and the system stopped responding over my LAN.
I have a backup of the config file so should be fine to recover.
So I re-flashed the freenasOS on the usb stick and on booting now with a monitor connected it can see all the drives, as it boots if gets to a point were it says
Then it just hangs on this line. Any ideas for getting the system up and running again?
I am going to try and reflash the USB stick off a install USB stick to see if that helps.
Error: no such column: lagg_deviceoptions
Error: no such column: stg_guiprotocol
moddlewared: setting up plugins (alert) [6/17] Then it just hangs on this line. Any ideas for getting the system up and running again?
