As I'm researching FreeBSD and FreeNAS, one of the items I don't quiet understand is whether I can run FreeNAS on FreeBSD. Obviously FreeNAS needs to run from a bootable device. In addition to experimenting with FreeBSD, I want to run a web server and a few other things on the box.
How do I install FreeBSD either on a separate device from FreeNAS, or ideally on the same device where FreeNAS is going to reside? This device is separate from storage devices. Once FreeBSD is installed, how do I
boot into FreeNAS since it doesn't work on a petitioned disk?
What is the recommended approach for restoring to previous working configuration since I will make mistakes and FreeNAS isn't the best candidate for visualization?
Thank you.
Thank you.
