FreeNas USB died and can't auto import Volumes
Sudsoft
My Freenas USB died yesterday. I reinstalled the latest version of Freenas on a new USB drive and booted up. I am able to access the console now and am able to see the 4 disks currently in my system. However, when I try to import the Volume on my FreeNas system I don't see anything coming up.
Anyone know how to troubleshoot this?
What FreeNAS version were you on previously? If might be helpful if you provide details of your FreeNAS hardware and configuration.
Jailer
Not strong, but bad
Did you upload a copy of your config after reinstalling?
Sudsoft
I believe I was on FreeNAS-9.10.2-U6 previously and just booted up with the current version. I have 4 hard drives.
Sudsoft
I haven't uploaded the config yet. I was just trying to import the volumes first. I have my config saved on my NAS but possibly somewhere else. Do you know the filename of the config?
As a guide to what hardware details you should be providing, refer to the Forum Guidelines.
Sudsoft
  • motherboard make and model - I don't have this. It is a Lenovo ThinkServer TS-140
  • Processor:
    Intel(R) Core(TM) i3-4130 CPU @ 3.40GHz (4 cores)
  • RAM quantity - 8 gb
  • hard drives, quantity, model numbers, and RAID configuration (don't remember what it is called / direct mirroring of 2 drives onto 2 drives)
Hard Drive details below:
Name
Pool
Serial
Disk Size
Adv. Power Management
Acoustic Level
Enable S.M.A.R.T.
ada0
WD-WCC4E5LRL49S
DISABLED
DISABLED
yes
more_vert
ada1
WD-WX51DA476NVT
DISABLED
DISABLED
yes
more_vert
ada2
WD-WX31DA43K2TS
DISABLED
DISABLED
yes
more_vert
ada3
WD-WCC4E6XJ76LX
DISABLED
DISABLED
yes
more_vert
If you can locate and upload your config, you won't have to auto import the disks. The config name syntax is <hostname>-FreeNAS-<version & build>-<date & time>.tar eg. freenas-l-FreeNAS-11.1-U7 (b45bfcf29)-20190310103735.tar
Chris Moore
Did you have your pool encrypted?
If you give the command zpool import at the command line, what is the response?
It should give you an output similar to this:
root@Emily-NAS:/tmp # zpool import
   pool: Backup
  state: ONLINE
 action: The pool can be imported using its name or numeric identifier.
        Backup                                          ONLINE
          raidz1-0                                      ONLINE
            gptid/2e919d3d-2c1a-11e9-af8b-00074306773b  ONLINE
            gptid/2f292da6-2c1a-11e9-af8b-00074306773b  ONLINE
            gptid/2fb95d07-2c1a-11e9-af8b-00074306773b  ONLINE
            gptid/30514e6b-2c1a-11e9-af8b-00074306773b  ONLINE
          raidz1-1                                      ONLINE
            gptid/41d3312f-2c1a-11e9-af8b-00074306773b  ONLINE
            gptid/426b7b47-2c1a-11e9-af8b-00074306773b  ONLINE
            gptid/43029d18-2c1a-11e9-af8b-00074306773b  ONLINE
            gptid/af54c9c6-4277-11e9-af8b-00074306773b  ONLINE
Sudsoft
It looks like my pool was encrypted that was why I wasn't able to see the pools. Once I uploaded the geli key, I was able to see the pool. Forgot that I had it encrypted. Is there any way to remove the encryption? I probably don't need them encrypted.
Apollo
You can't unencrypt the pool. You can set it without passphrase though.
If you need to have your pool unencrypted, you will need to replciate to a new pool/volume which is not encrypted.
Chris Moore
It might have helped future users of the forum if you would have shared some steps in your process.
