derio
- Mar 25, 2016
Hello everybody, I am a unix noob but somehow, following documentation and tutorials, managed to get a FreeNAS server up and running.
I wanted to upgrade two of my 3T Barracuda drives (ST3000DM001-1CH166) to the new version (used the guide over there). I downloaded the firmware (Barracuda-ALL-GRCC4H.iso) but during the upgrade itself I got the message that the drive model was wrong.. It printed that the firmware was not downloaded to the devices and that I should reboot.
As I rebooted from my FreeNAS usb I got a bunch of errors like
"django.db.utils.DatabaseError: no such column: system_advanced.adv_firmwarevc"
and it seems that all the settings are gone. The nginx server also does not start.
If I open a shell and type
"zpool status"
I get "no pools available"
With "zpool import"
I get
pool: dNAS
state: UNAVAIL
status: The pool is formatted using an incompatible version.
action: The pool cannot be imported. Access the pool on a system running newer
software, or recreate the pool from backup.
see: http://www.sun.com/msg/ZFS-8000-A5
dNAS UNAVAIL newer version
raidz1-0 ONLINE
gptid/1...... ONLINE
gptid/2...... ONLINE
gptid/3...... ONLINE
In the /data folder there is a freenas-v1.db but was last modified half an hour ago and the freenas-v1.db.bak is 3 years old..
Can something be done to restore the settings (and the pool) without risk of losing data?
Thanks in advance
Edit: Some extra info: My version is FreeNAS-9.2.0-RELEASE-x64 and I seem to have a month-old db backup but that was before I replaced one faulty drive and resilvered. Could I use this?
"zpool status"
With "zpool import"
I get
pool: dNAS
state: UNAVAIL
raidz1-0 ONLINE
Thanks in advance
