Galoot
 - Dec 30, 2019
Hi all - I've been using Plex for a little while with another FreeNAS system. I've recently built a new FreeNAS system and I'm having issues with permissions with PLEX being able to scan new files I drop into the source area (exisiting files are working fine).
The only workaround is to manually apply recursive permissions for the DataSet under the Pool>Edit Permissions every time. I've googled this to death and tried all sorts of things and it's driving me a bit nuts.
When I look at the permissions in Linux using SSH the permissions on the root of the mounted dataset look the same as the permissions on working file (as does the file that isn't scanned\picked up). But when I look in Windows (using SMB share) the permissions on the root of the dataset are blank which I'm thinking is maybe the problem. Also the permissions on a working file\directory and the non working file\directory are different in Windows. To me it looks like root is missing permissions until I manually apply recursive permissions. But not sure why this wouldn't show when doing ls -al on the command line hence my confusion.
Is anyone able to help me troubleshoot this please?
Thanks
Tim
Thanks
Tim
