ASUS Prime Z97-A - i7-4770 - 12gb 1333 RAM - mirrored usb boot drive
For years, Ive been using the onboard 1gb lan port but recently I upgraded everything I have to 10g.
My whole netowk is Unifi.
I just installed their 10g switch. The server networked fine with the new 10g switch with the 1g port on the motherboard.
Then I installed a Chelsio 520-BT dual ethernet 10g card. Again, everything worked fine.
Today, I powered it off to install an LSI 9210-8i (IT mode). The drives its powering are showing up.
I turned the machine back on and now I get "The web interface could not be accessed." The light on my switch is not lit up so I know its not networked.
But I havnt changed anything other than adding the LSI HBA.
I tried accessing the web page with no luck. I tried resetting network settings from FreeNAS menu. I tried a few reboots. Nothing.
Im going to keep playing, but thought I should ask here in case Im missing something. FreeNAS does see the card when booting.
