TerryVog
- Dec 5, 2015
Several times a day, my FreeNAS server reboots:
freenas.local had an unscheduled system reboot. The operating system successfully came back online at Tue May 5 10:05:39 2020.
This occurs since upgrading from 11.2 to 11.3-U2.1. I saw a post on this forum, suggesting that it is a known bug and the temporary workaround is to disable SMART, so I did. I also upgraded the ZFS Pool with newer ZFS feature flags. But the problem remained.
I use my FreeNAS server to make TimeMachine backups, but at the moment, the server's uptime is too low to start backing up to it.
Specs: Intel Core i3-3240 CPU @ 3.40GHz, 16GB ram and 4 disks, 3TB each
