Hi All,
I've had a problem with FreeNAS in that when it's being given some work (I'm saving a Windows Server Backup to it over CIFS) it hangs, stops serving the CIFS share, and eventually reboots itself. When this occurs, there's a ton of console messages logged one after the other saying
CAM status: Command timeout
g_vfs_done (): da0...write... error=5
Error 5, retries exhausted
(Sorry they're not the most accurate representations, I'm writing them from memory)
da0 is the USB drive I have FreeNAS installed to, so I've tried a different pen drive to see if that helped but it didn't make a difference. Both pen drives are 2GB.
Hardware is an Intel Core 2 Quad Q6600 and 4GB (2 x 2GB) DDR2 RAM, and a 2TB Seagate Barracuda drive being used for storage.
I've just reinstalled FreeNAS using the 9.3 Beta to see if that makes any difference, which it seems to have so far as I've copied almost 10GB without issue, whereas previously it would struggle to get beyond 3GB before failing.
Is this a common or known issue?
Thanks,
B
Thanks,
B
