JohnDigital
- Jan 7, 2015
Now try http://192.168.0.11
That has fixed my issue, thank you John. I really appreciate it.service proftpd stop && service nginx start
Your running your ftp on port 443
Thank youOnce thats all done and you can reach the gui again, log in and change your ftp port to the usual port 21
Although I do now have the issue of my jails posting a "Error: [EFAULT] No default interface found" error nowThen reboot, and all should be happy.. Also a great time to do a config backup and some manual snapshots ;)
They're selected to use em0 and yes they're running 172 addresses, still don't work.So in the properties of each jail select the interface em0
See that's the weird thing, my router hasn't changed. It just randomly stopped working.I think your old router was likely using a 172 adress for its internal networking when you set the jails up and it borked everything as your new settings are 192.
Yeah so without changing anything this is what Plex does lmaoSo your plex jail is DHCP start it and what does it say? Does it start clean?
iocage start plex
Yeah, Id edit the jail properties for each jail and assign them all IPs in your 192.168.0. subnet, and you must also set the correct gateway (defaultrouter).
Now a smart person would actually set the default route to 192.168.0.1, I on the other hand didn't pay attention when I was doing everything. (For the record I did change it to 192.168.0.1 afterwards and it works fine I just want to be able to set it back to the way it was)Im also wondering if NAT is causing some issues. Normally its not needed.
