Freenas dies after a while
GodAtum
I can boot up freenas fine, but after a day or so it dies with the error:
frame 0xfffffe0000356000 timed out command 0x1BF8400
error 60 in callback from mfi_send_frame
After a reset its back up fine. Version is FreeNAS-9.3-STABLE-201512121950
adrianwi
You'll get more help if you let people know your system specs, which might help identify the problem.
gpsguy
Active Member
FreeNAS requires a minimum of 8GB of RAM.
BTW, we don't recommend virtualizing a production server, but if you really want to do it, please read the stickies on the subject.
Robert Trevellyan
Pony Wrangler
It's been running OK for the past few years.
Hmm.
Almost certainly a problem with your RAID array.
This will sound like carping, but here goes anyway ... now would be a great time to make sure you have a tested backup of everything you care about.
GodAtum
Ive got a weekly backup to a USB hard drive. I'll probably delete the array from my PERC and hopefully that will pass SMART status to freenas (apparently it support pass-through/JBOD for those disks not part of an array). Then i can tell if a drive failed.
yes I have. it's just a small NAS at home. It's been running OK for the past few years.
They're called minimum requirements for a very good reason. There are alternative NAS solutions out there that might appeal more to your limited resources.
