Pelasgians
- Mar 7, 2020
Hello fellow FreeNasers,
Build Link: https://pcpartpicker.com/list/Zj3Lp8
What i Plan to use this build for:
Backing up my PC (My PC has a capacity of 3 TB of data and i need somewhere to put 3TB of data. I have a 1 TB SSD for OS and a few games, and 2 1 TB HD's running in Raid 0 that has mainly my steamgames (Nothing i can't replace with time).
Maybe run a plex server with between 1-3 1080P Streams
All of the drives need to be encrypted and i plan to run a Raid 5 setup with those 4 drives with the possibility of up to 8 which leads me to questions
Questions:
Does FreeNAS support PCI 3 x1 sata cards incase i want to add more drives
Does FreeNas have decent Ryzen support and does it support HW Transcoding with a 8 GB RX580 i have laying around collecting dust
Can i get away with this budget CPU with AES Acceleration if in fact FreeNas supports GPU Offloading to a RX 580.
How important is ECC memory for just home use?
Future Setup:
I might end up adding 4 more drives in another Raid 5 Config, but that won't be until i need more space. It will be mainly just be me using this to backup stuff.
Questions:
Future Setup:
