sonny81
- Aug 7, 2012
- Yes, set it to 1500.
- Back to the default, yes.
- Yes, all back to default.
- If it's still green, i.e. 1000 full duplex on the DLink, you can leave it.
- Probably a good idea at this point. ;)
Jumbo frames need to be enabled end-to-end or you will get all sorts of strange network errors. By default everything assumes 1500. Given that you are troubleshooting network issues let switch back to the default. Once it's working properly if you want/need to you can try turning jumbo frames back on.
Great reply!!
Alright I've done all you said on my desktop. Switch light and NIC light is still green so that's cool.
I actually bought two of those Intel NICs. Do you recommend I installed one on the NAS and one on the desktop? My desktop NIC is a Marvell Yukon 88E8056.
If I decide to turn on the jumbo frames again I just go into the GUI under network interfaces and type in mtu 9000 correct? If I'm missing a step please let me know.
I'll give you a status update tomorrow as soon as I get some proper NICs installed :)
