Freenas and a lot of errors
Maninblack
Freenas and a bunch of errors
Hey, hope someone can help me out.
Last week I got an error message saying bad sectors so replaced the drive. The resilvering process took over 100 hours. Then after a restart yesterday freenas started resilvering again. So I left it and this morning when I checked. There were now these error messages
1) ada7 2 currently unreadable
(pending) sectors
2) ada5 2 currently unreadable
(pending) sectors
3) ada3 ATA error increased from 4 to
10
Ada3 is the drive I’ve recently replaced.
This is the status log
Shell
[root@freenas ~]# zpool status -v
pool: J******
state: ONLINE
status: One or more devices is currently being resilvered. The pool will
continue to function, possibly in a degraded state.
action: Wait for the resilver to complete.
scan: resilver in progress since Tue Jun 8 22:06:40 2021
1.32T scanned out of 15.2T at 26.6M/s, 151h48m to go
166G resilvered, 8.72% done
NAME STATE READ WRITE CKSUM
Jarvis ONLINE 0 0 0
raidz2-0 ONLINE 0 0 0
gptid/4fd0edac-5eb8-11e5-8317-d050996490b6 ONLINE 0 0 0
gptid/e0cc7676-18ed-11ea-b434-d050996490b6 ONLINE 0 0 0
gptid/50aecb0b-5eb8-11e5-8317-d050996490b6 ONLINE 0 0 0
gptid/934bee96-c498-11eb-b843-d050996490b6 ONLINE 0 0 0 (resilvering)
gptid/51904b0f-5eb8-11e5-8317-d050996490b6 ONLINE 0 0 0
gptid/5202b9d8-5eb8-11e5-8317-d050996490b6 ONLINE 0 0 0
gptid/5275d7e4-5eb8-11e5-8317-d050996490b6 ONLINE 0 0 0
gptid/52ee6b39-5eb8-11e5-8317-d050996490b6 ONLINE 0 0 0
/mnt/J*******/Media/Movies/E********/E********.mkv
pool: freenas-boot
state: ONLINE
scan: scrub repaired 0 in 0h3m with 0 errors on Fri Jun 4 03:48:35 2021
freenas-boot ONLINE 0 0 0
gptid/a6612988-8d5e-11e6-aa3b-d050996490b6 ONLINE 0 0 0
errors: No known data errors
System spec
Freenas 9.10.2-U6 (booting from usb stick)
CPU intel atom c2750 2.4GHz
ECC Ram 32711MB
8 WD Red 3TB HDD
Any help would be greatly appreciated
Thanks in advance
Alecmascot
Alecmascot
Then that's your problem.
Maninblack
Oh right, never saw that when I built the machine 6 years ago. So is it a case of scrap everything and start again?
Redcoat
I suggest you check all your drive part numbers - I don't believe that EFAX is older than 2 years or so, maybe less. If you have 6-yrear old Reds I would expect them to be EFRX (which are "good" CMR's). Only SMR drives are a problem and suggested for replacement to avoid the resilvering times issue that you experienced.
Maninblack
After doing a bit of digging around it looks like that’s the problem that the original drives are CMR and the new one is the SMR kind. So I’m guessing that’s the thing that’s causing the clash. I’m going to return the new drive and get a CMR drive, hopefully this solves it. Will update when I get the new ones.
Thanks for the help everyone
Redcoat
If you want to stick with WD, you need to get a Red Plus ( which is CMR).
