Running the "wbinfo -u" results in no output at all.
Here are the contents of the smb4.conf file...
login as: root
root@freenas.nightnetworks.net's password:
Last login: Wed Mar 8 00:41:45 2017 from 192.168.1.28
FreeBSD 10.3-STABLE (FreeNAS.amd64) #0 41eb257(9.10.2-STABLE): Mon Mar 6 17:03: 14 UTC 2017
FreeNAS (c) 2009-2016, The FreeNAS Development Team
All rights reserved.
FreeNAS is released under the modified BSD license.
For more information, documentation, help or support, go here:
http://freenas.org
Welcome to FreeNAS
[root@freenas] ~# more /usr/local/etc/smb4.conf
[global]
username map = /usr/local/etc/smbusers
server max protocol = SMB3
interfaces = 127.0.0.1 192.168.1.13
bind interfaces only = yes
encrypt passwords = yes
dns proxy = no
strict locking = no
oplocks = yes
deadtime = 15
max log size = 51200
max open files = 469802
logging = file
load printers = no
printing = bsd
printcap name = /dev/null
disable spoolss = yes
getwd cache = yes
guest account = nobody
map to guest = Bad User
obey pam restrictions = yes
directory name cache size = 0
kernel change notify = no
ea support = yes
store dos attributes = yes
lm announce = yes
hostname lookups = yes
acl allow execute always = true
dos filemode = yes
multicast dns register = yes
domain logons = yes
idmap config *: backend = tdb
server role = member server
workgroup = NIGHTNETWORKS
realm = NIGHTNETWORKS.NET
security = ADS
client use spnego = yes
cache directory = /var/tmp/.cache/.samba
local master = no
domain master = no
preferred master = no
ads dns update = yes
winbind cache time = 7200
winbind offline logon = yes
winbind enum users = yes
winbind enum groups = yes
winbind nested groups = yes
winbind use default domain = no
winbind refresh tickets = yes
idmap config NIGHTNETWORKS: backend = rid
idmap config NIGHTNETWORKS: range = 20000-90000000
allow trusted domains = no
client ldap sasl wrapping = plain
template shell = /bin/sh
template homedir = /home/%D/%U
netbios name = FREENAS
pid directory = /var/run/samba
create mask = 0666
directory mask = 0777
client ntlmv2 auth = yes
dos charset = CP437
unix charset = UTF-8
log level = 1
[Archive]
path = /mnt/Data/Archive
printable = no
veto files = /.snapshot/.windows/.mac/.zfs/
writeable = yes
browseable = yes
vfs objects = zfs_space zfsacl streams_xattr aio_pthread
hide dot files = yes
guest ok = no
nfs4:mode = special
nfs4:acedup = merge
nfs4:chown = true
zfsacl:acesort = dontcare
[Backups-Images]
path = /mnt/Data/Backups and Images
printable = no
writeable = yes
browseable = yes
guest ok = no
nfs4:mode = special
nfs4:acedup = merge
nfs4:chown = true
[Data]
path = /mnt/Data
printable = no
writeable = yes
browseable = yes
guest ok = no
nfs4:mode = special
nfs4:acedup = merge
nfs4:chown = true
[GoPro Video]
path = /mnt/Data/GoPro Video
printable = no
writeable = yes
browseable = yes
guest ok = no
nfs4:mode = special
nfs4:acedup = merge
nfs4:chown = true
[Home Folders]
path = /mnt/Data/Home Folders
printable = no
writeable = yes
browseable = yes
guest ok = no
nfs4:mode = special
nfs4:acedup = merge
nfs4:chown = true
[Media00]
path = /mnt/Data/Media00
printable = no
writeable = yes
browseable = yes
guest ok = no
nfs4:mode = special
nfs4:acedup = merge
nfs4:chown = true
[Media01]
path = /mnt/Data/Media01
printable = no
writeable = yes
browseable = yes
guest ok = no
nfs4:mode = special
nfs4:acedup = merge
nfs4:chown = true
[Media02]
path = /mnt/Data/Media02
printable = no
writeable = yes
browseable = yes
guest ok = yes
nfs4:mode = special
nfs4:acedup = merge
nfs4:chown = true
[Media03]
path = /mnt/Data/Media03
printable = no
writeable = yes
browseable = yes
guest ok = yes
nfs4:mode = special
nfs4:acedup = merge
nfs4:chown = true
[Plex Temp]
path = /mnt/Data/Plex Temp
printable = no
writeable = yes
browseable = yes
guest ok = no
nfs4:mode = special
nfs4:acedup = merge
nfs4:chown = true
[Software]
path = /mnt/Data/Software
printable = no
writeable = yes
browseable = yes
guest ok = no
nfs4:mode = special
nfs4:acedup = merge
nfs4:chown = true
[TEMP]
path = /mnt/Data/Temp
printable = no
writeable = yes
browseable = yes
guest ok = no
nfs4:mode = special
nfs4:acedup = merge
nfs4:chown = true
[root@freenas] ~#
Thank You!
