[FreeNAS 9 Plugins] - SAB / SB / CP / HP / Maraschino / HTPC / Mylar / LL / Gamez
Joshua Parker Ruehlig
@CraftyClown
So I was able to build Mylar with openssl 1.0.1i, but then when I try doing its initial version check I get "Could not get the latest commit from github"
Maybe if you point me to where you and the dev are debugging this I can joing the conversation?
Thanks
CraftyClown
CraftyClown
@Joshua Parker Ruehlig
Not sure if you saw this Josh...
"It looks like he's getting that error due to the versioncheck module not using the requests module - something must have changed with the version of openssl (or python, or something).
Regardless, I needed to update the versioncheck module to use the requests module anyways - so I'll try and get it out in a bit for ya to test out (or for him to test out if he hasn't pushed it out to his base yet)."
yup, I saw that. so sounds like we need to wait till he has an update then test again with the latest openssl. hopefully it all works then.
CraftyClown
Morning Josh,
He's managed to get an update out for you to add to the package. Hopefully with the up to date OpenSSL it will start working again :)
Morning Josh,
Great, I'll look into it tonight.
Did you have any joy?
I took a look but didnt test it. he didn't push it to master yet so I can't issue an update with the fix till he does so.
CraftyClown
Ok, seems he can't push it to master yet as he is having some other issues in the dev build and wants to hold off until he has fixed those.
I take it that means while it's still on the dev branch, there's not much we can do?
I'll just test it to make sure updates on dev work. but I can't issue an updated PBI till the fix is in master. he could create another fork, and apply it to master but it's up to him how he manages this.
Grasfer
Has this happend to anyone else that after post process the episode dissapear from the list?
Like episode 1 of new suits dissapeard after it downloaded and post-processed it. Happend to alot of other series to.
CraftyClown
Hey Grasfer,
I'm not seeing the same behaviour. Suits downloaded and post processed for me without problems and episode one is still showing in Sick rage.
Are you on the Master or Dev branch? I'm currently on master.
Grasfer
Hey Grasfer,
Master.
I'm not 100% sure but if i download a serie manual and set it to process for tv then the episode is still in the list. But when sickrage think the quality is bad and wants to redownload a better version sometimes episodes dissapear.
Really weird.
I tracked it down to python not being able to find the roor certificate chain.
Fixed version, with latest SSL, will be in the FreeNAS repo tomorrow.
Rhino5
I'm having a rather difficult time with something that should be simple. I'm trying to add unrar to sabnzbd in rather spectacularly unsuccessful fashion. By all rights I should have gotten this right just randomly by now, but nope. Could you help an old, not so bright guy out?
the sabnzbd plugin includes unrar.
sabnzbd shows and logs an error if it doesn't find unrar. is this what you're seeing?
Yes, my sabnzbd is not seeing unrar.
guessing you uninstalled something (maybe couchpotato) from the sabnzbd jail?
this should fix it.
ln -s /usr/pbi/sabnzbd-amd64/bin/unrar /usr/local/bin
