Mike Wright
 - Dec 11, 2015
Two days ago, I was able to install and get FreeNas 9.3 running on my machine (specs below). After getting it set up, I shut it down until I could work on it some more. Now, it won't start up and is always stuck at the following backtrace in KDB (abbreviated output since I have to type it by hand):
Fatal trap 12: page fault while in kernel mode
cpuid = 0; apic id = 00
fault virtual address = 0x0
fault code = supervisor write data, page not present
instruction pointer = 0x20
stack pointer = 0x28
frame pointer = 0x28
code segment = base 0x0, limit 0xfffff, type 0x1b
= DPL 0, pres 1, long 1, def32 0, gran 1
processor eflags = resume, IOPL = 0
current process = 0 ()
[ thread pid 0 tid 0 ]
Stopped at vm_pageq_remove+0x60: movq %rdx,(%r9)
db> bt
Tracing pid 0 tid 0 0xffffffff8162cef0
vm_pageq_remove() at +0x60
vm_fault_hold() at +0x39b
vm_fault() at +0x73
vm_fault_wire() at +0x4e
vm_map_wire() at +0x309
kmem_alloc at +0xcb
vm_ksubmap_init at +0x64
cpu_startup() at +0xf0
mi_startup() at +0x7b
btext() at +0x2c
Specs:
ASUS M2N32-SLI Deluxe
AMD Athlon 64 X2 Dual Core 6000+
8GB RAM (8192 MB)
SanDisk 32GB USB drive for OS (mounted internally)
4 x 6TB HGST Deskstar NAS drives (H3IKNAS600012872SN)
1000W PSU
What I've tried so far:
Other weird bits of information:
db> bt
vm_fault() at +0x73
kmem_alloc at +0xcb
btext() at +0x2c
Specs:
8GB RAM (8192 MB)
1000W PSU
- Tons of searches for similar issues. I'm only finding stuff that has been resolved since around version 8.0.3
 - Reinstalled FreeNAS. Was getting trap 12 during this (same as above backtrace), but got past it somehow.
 - Updated motherboard BIOS
- KDB is showing "real memory = 9663676416 (9216 MB)". I feel like this might be relevant since FreeNAS may be attempting to access memory that isn't there (a full GB extra), in the kmem_alloc() call.
