Angus
 - Aug 17, 2014
Recently my NAS was working well and then it disappeared from view for any computer or device that was able to access it.
I attempted to access it using the WebGUI, but that failed.
NAS console monitor explains "No configured interfaces were found".
I tried the "Configure Network Interfaces" from the console menu, by pressing "1" but it does not execute as described in other posted guidance.
I only get the option of pressing "q to quit".
I have attached an image of the console where it continues to state that "host name not found"
I also tried to access the configuration file from the boot USB by removing it and attempting to read it on a PC, but the USB was not readable - Windows wanted to format it...which I did not do.
Any ideas?
Can I simply reinstall FreeNAS and continue on like nothing happened, or is that wishful thinking?
Thank you.
Any ideas?
Thank you.
290.5 KBViews: 4
