I was previously using MiniDLNA on FreeNAS version 8.3.x and had installed it using the old jail method/PBI and it work fantastically. Since upgrading to FreeNAS 9.1.1 and installing MiniDLNA under the new jail system I have been unable to access it using clients reliably.
If I use a client that is hard wired to the network the MiniDLNA server is visible (although it drops in and out every now and again) but if I try to connect to the server using a wireless client (phone etc) the MiniDLNA server does not show (it has once or twice but its flaky at best).
I have read quite a bit into this and at first expected there to be an issue with my router and wireless isolation, but the router is fine, also it worked under the previous FreeNAS version and PBI.
Does it have anything to do with this thread?
http://forums.freenas.org/threads/bonjour-broken-when-jails-enabled.14792/
Any ideas?
Any ideas?
