Freenas 8 as an iScsi Initiator
Is it possible to use Freenas 8 as an iScsi Initiator for another Freenas ? In 7 it can be done, but can't find the option in 8
What I am trying to do is as follows:
Make a ZVOL mirror using an internal disk, with an isci target on another Freenas
J
James
Guest
From http://doc.freenas.org/index.php/ISCSI#Initiators:
NOTE: beginning with 8.2, FreeNAS™ contains iscontrol(8). This utility allows the FreeNAS™ system to act as an initiator (rather than a target) and must be run from the command line. If you create a custom configuration for iscontrol, back it up as it will not survive a reboot of the system.
Thanks.
But is what I am trying to achieve possible? Mirror with iscsi targets residing on other FreeNas boxes?
