FreeNAS 8.3 Will Not retain ZFS Pool
ghostlobster
Hmmm...no luck there...here's what I got:
[root@freenas ~]# zpool export RAID
cannot open 'RAID': no such pool
[root@freenas ~]# zpool export -f RAID
[root@freenas ~]#
just for the hell of it I'll restart the box and see what happens. I may have hosed things a bit with that import -f before. I doubt that it'll change anything but it'll give me something to do for a few moments.
Nope, no different after a reboot.
Here's a zpool status...nothing surprising here.
[root@freenas ~]# zpool status
no pools available
Should I try a zpool import first, no options or -f flag before the export?
paleoN
A blank zpool import, what I asked for, will list available pools for import.
Does the GUI think any pools are imported? If so export the pool from the GUI, do not mark disks as new.
Otherwise, I suppose we could always delete the zpool cache file:
mount -uw /
rm /data/zfs/zpool.cache
shutdown -r now
The last command will reboot the system obviously.
ghostlobster
Things appear pretty weird in my world. Here's what I'm looking at right now:
Nothing is listed in the storage panel in the GUI where zfs volumes would be. All disks do appear in the view disks page, but within Active Volumes, nothing is listed.
also, the zpool.cahe file does not exist:
[root@freenas ~]# mount -uw /
[root@freenas ~]# rm /data/zfs/zpool.cache
rm: /data/zfs/zpool.cache: No such file or directory
A ls in the /data/zfs directory shows that it's empty as well:
[root@freenas /data/zfs]# ls
Wow, thoughts? Ideas? Flamethrowers?
paleoN
ghostlobster
This:
[root@freenas ~]# zpool import
   pool: RAID
  state: FAULTED
 status: One or more devices contains corrupted data.
 action: The pool cannot be imported due to damaged devices or data.
        The pool may be active on another system, but can be imported using
        the '-f' flag.
   see: http://www.sun.com/msg/ZFS-8000-5E
        RAID                      FAULTED  corrupted data
          raidz1-0                ONLINE
            4140409436293275748   UNAVAIL  corrupted data
            13949890047348135266  UNAVAIL  corrupted data
            12864383027183141833  UNAVAIL  corrupted data
          14728624880139133829    UNAVAIL  corrupted data
[root@freenas ~]#
paleoN
I would try doing a Factory Restore at this point. It doesn't touch the pool.
If zpool import is still the same afterwards give mfsBSD a shot.
ghostlobster
OK...factory reset.
change in results:
   pool: RAID
  state: ONLINE
 action: The pool can be imported using its name or numeric identifier.
   see: http://www.sun.com/msg/ZFS-8000-4J
        RAID                                            ONLINE
          raidz1-0                                      ONLINE
            gptid/32ea520c-031e-11e2-b182-000acd1fbb8d  ONLINE
            gptid/35b37ca9-031e-11e2-b182-000acd1fbb8d  ONLINE
            gptid/36a53dae-031e-11e2-b182-000acd1fbb8d  ONLINE
With that 4th item showing as unavailable, is that going to be a major issue? I have not run any commands on anything except that import command to see what's there.
paleoN
Yes, it's a major issue. That's the top level single disk stripe vdev. The one with no redundancy.
Let's see what happens with:
zpool import -R /mnt -o failmode=continue -o rdonly=on RAID
paleoN
I was/am expecting the above command to fail. Though it might work.
Assuming it failed, it would be nice to see a current glabel status. In addition the output of zdb -l /dev/adaXp2 for the remaining 3 drives.
It's also past time to run some long tests against all your disks:
smartctl -t long /dev/ada1
smartctl -t long /dev/ada2
smartctl -t long /dev/ada3
smartctl -t long /dev/ada4
ghostlobster
Sorry for the delay in responding, I've got family in town and was summoned to them yesterday.
Yes, that command cratered with an exception yesterday. Unfortunately, I didn't make a note of it as I had other things going on.
OK, zdb -l /dev/ada1p2 output:
LABEL 0
    version: 28
    state: 0
    txg: 192838
    pool_guid: 10036866808421506734
    hostid: 1362761028
    hostname: 'freenas.local'
    top_guid: 11941661085329332228
    guid: 12864383027183141833
    vdev_children: 2
    vdev_tree:
        type: 'raidz'
        nparity: 1
        metaslab_array: 23
        metaslab_shift: 31
        ashift: 9
        asize: 2994157387776
        is_log: 0
        children[0]:
            type: 'disk'
            guid: 4140409436293275748
            path: '/dev/gptid/32ea520c-031e-11e2-b182-000acd1fbb8d'
            phys_path: '/dev/gptid/32ea520c-031e-11e2-b182-000acd1fbb8d'
            whole_disk: 0
            DTL: 54
        children[1]:
            type: 'disk'
            guid: 13949890047348135266
            path: '/dev/gptid/35b37ca9-031e-11e2-b182-000acd1fbb8d'
            phys_path: '/dev/gptid/35b37ca9-031e-11e2-b182-000acd1fbb8d'
            whole_disk: 0
        children[2]:
            type: 'disk'
            path: '/dev/gptid/36a53dae-031e-11e2-b182-000acd1fbb8d'
            phys_path: '/dev/gptid/36a53dae-031e-11e2-b182-000acd1fbb8d'
            whole_disk: 0
LABEL 1
    version: 28
    state: 0
    txg: 192838
    hostid: 1362761028
    vdev_children: 2
    vdev_tree:
        type: 'raidz'
        nparity: 1
        metaslab_array: 23
        metaslab_shift: 31
        ashift: 9
        is_log: 0
        children[0]:
            type: 'disk'
            whole_disk: 0
            DTL: 54
        children[1]:
            type: 'disk'
            whole_disk: 0
        children[2]:
            type: 'disk'
            whole_disk: 0
LABEL 2
    version: 28
    state: 0
    txg: 192838
    hostid: 1362761028
    vdev_children: 2
    vdev_tree:
        type: 'raidz'
        nparity: 1
        metaslab_array: 23
        metaslab_shift: 31
        ashift: 9
        is_log: 0
        children[0]:
            type: 'disk'
            whole_disk: 0
            DTL: 54
        children[1]:
            type: 'disk'
            whole_disk: 0
        children[2]:
            type: 'disk'
            whole_disk: 0
LABEL 3
   version: 28
    state: 0
    txg: 192838
    hostid: 1362761028
    vdev_children: 2
    vdev_tree:
        type: 'raidz'
        nparity: 1
        metaslab_array: 23
        metaslab_shift: 31
        ashift: 9
        is_log: 0
        children[0]:
            type: 'disk'
  is_log: 0
        children[0]:
            type: 'disk'
            whole_disk: 0
            DTL: 54
        children[1]:
            type: 'disk'
            whole_disk: 0
        children[2]:
            type: 'disk'
            whole_disk: 0
zdb -l /dev/ada2p2 output:
LABEL 0
    version: 28
    state: 0
    txg: 192838
    hostid: 1362761028
    vdev_children: 2
    vdev_tree:
        type: 'raidz'
        nparity: 1
        metaslab_array: 23
        metaslab_shift: 31
        ashift: 9
        is_log: 0
       children[0]:
            type: 'disk'
            whole_disk: 0
            DTL: 54
        children[1]:
            type: 'disk'
            whole_disk: 0
        children[2]:
            type: 'disk'
            whole_disk: 0
LABEL 1
    version: 28
    state: 0
    txg: 192838
    hostid: 1362761028
    vdev_children: 2
    vdev_tree:
        type: 'raidz'
        nparity: 1
        metaslab_array: 23
        metaslab_shift: 31
        ashift: 9
        is_log: 0
        children[0]:
            type: 'disk'
            whole_disk: 0
            DTL: 54
        children[1]:
            type: 'disk'
            whole_disk: 0
        children[2]:
            type: 'disk'
            whole_disk: 0
LABEL 2
    version: 28
    state: 0
    txg: 192838
    hostid: 1362761028
    vdev_children: 2
    vdev_tree:
        type: 'raidz'
        nparity: 1
        metaslab_array: 23
        metaslab_shift: 31
        ashift: 9
        is_log: 0
        children[0]:
            type: 'disk'
            whole_disk: 0
            DTL: 54
        children[1]:
            type: 'disk'
            whole_disk: 0
        children[2]:
            type: 'disk'
            whole_disk: 0
LABEL 3
   version: 28
    state: 0
    txg: 192838
    hostid: 1362761028
    vdev_children: 2
    vdev_tree:
        type: 'raidz'
        nparity: 1
        metaslab_array: 23
        metaslab_shift: 31
        ashift: 9
        is_log: 0
        children[0]:
            type: 'disk'
        is_log: 0
        children[0]:
            type: 'disk'
            whole_disk: 0
            DTL: 54
        children[1]:
            type: 'disk'
            whole_disk: 0
        children[2]:
            type: 'disk'
            whole_disk: 0
zdb -l /dev/ada3p2 output:
LABEL 0
    version: 28
    state: 0
    txg: 192838
    hostid: 1362761028
    vdev_children: 2
    vdev_tree:
        type: 'raidz'
        nparity: 1
        metaslab_array: 23
        metaslab_shift: 31
        ashift: 9
        is_log: 0
      children[0]:
            type: 'disk'
            whole_disk: 0
            DTL: 54
        children[1]:
            type: 'disk'
            whole_disk: 0
        children[2]:
            type: 'disk'
            whole_disk: 0
LABEL 1
    version: 28
    state: 0
    txg: 192838
    hostid: 1362761028
    vdev_children: 2
    vdev_tree:
        type: 'raidz'
        nparity: 1
        metaslab_array: 23
        metaslab_shift: 31
        ashift: 9
        is_log: 0
        children[0]:
            type: 'disk'
            whole_disk: 0
            DTL: 54
        children[1]:
            type: 'disk'
            whole_disk: 0
        children[2]:
            type: 'disk'
            whole_disk: 0
LABEL 2
    version: 28
    state: 0
    txg: 192838
    hostid: 1362761028
    vdev_children: 2
    vdev_tree:
        type: 'raidz'
        nparity: 1
        metaslab_array: 23
        metaslab_shift: 31
        ashift: 9
        is_log: 0
        children[0]:
            type: 'disk'
            whole_disk: 0
            DTL: 54
        children[1]:
            type: 'disk'
            whole_disk: 0
        children[2]:
            type: 'disk'
            whole_disk: 0
LABEL 3
   version: 28
    state: 0
    txg: 192838
    hostid: 1362761028
    vdev_children: 2
    vdev_tree:
        type: 'raidz'
        nparity: 1
        metaslab_array: 23
        metaslab_shift: 31
        ashift: 9
        is_log: 0
        children[0]:
            type: 'disk'
      is_log: 0
        children[0]:
            type: 'disk'
            whole_disk: 0
            DTL: 54
        children[1]:
            type: 'disk'
            whole_disk: 0
        children[2]:
            type: 'disk'
            whole_disk: 0
And, just for the hell of it, zdb -l /dev/ada4p2 output:
LABEL 0
    version: 28
    state: 0
    txg: 192838
    hostid: 1362761028
    top_guid: 14728624880139133829
    vdev_children: 2
    vdev_tree:
        type: 'disk'
        path: '/dev/gptid/29ace990-0420-11e2-ba6f-000acd1fbb8d'
        phys_path: '/dev/gptid/29ace990-0420-11e2-ba6f-000acd1fbb8d'
        whole_disk: 0
        metaslab_array: 742
        metaslab_shift: 30
        ashift: 9
       asize: 998052462592
        is_log: 0
LABEL 1
    version: 28
    state: 0
    txg: 192838
    hostid: 1362761028
    vdev_children: 2
    vdev_tree:
        type: 'disk'
        whole_disk: 0
        metaslab_array: 742
    vdev_children: 2
    vdev_tree:
        type: 'disk'
        whole_disk: 0
        metaslab_array: 742
        metaslab_shift: 30
        ashift: 9
        asize: 998052462592
        is_log: 0
LABEL 2
failed to unpack label 2
LABEL 3
failed to unpack label 3
[root@freenas ~]#
Interesting output on ada4!
Now, the long tests...how do I get the results of it? When I enter the command for each one, I get the following for each one. I'm guessing it's running in the background:
[root@freenas ~]# smartctl -t long /dev/ada4
smartctl 5.43 2012-06-30 r3573 [FreeBSD 8.3-RELEASE-p4 amd64] (local build)
Copyright (C) 2002-12 by Bruce Allen, http://smartmontools.sourceforge.net
=== START OF OFFLINE IMMEDIATE AND SELF-TEST SECTION ===
Sending command: "Execute SMART Extended self-test routine immediately in off-li
ne mode".
Drive command "Execute SMART Extended self-test routine immediately in off-line
mode" successful.
Testing has begun.
Please wait 176 minutes for test to complete.
Test will complete after Sat Oct 13 10:40:27 2012
Use smartctl -X to abort test.
[root@freenas ~]#
I'll run the glabel status later on this afternoon, right now, if the other tests are running in the background, I don't want to stress it too much.
I've now got family bellowing to me, but wanted to get as much data as I could to you and anyone else. I appreciate this help so much, you have no idea! Thanks a bunch...regardless of the outcome, your help is very very appreciated.
paleoN
I wouldn't mind seeing what it was, but I at least wouldn't be able to do anything with it.
Yes, AFAICT this indicates that ada4 is the single disk vdev. It's missing the last two labels which are located at the end of the partition. It's also the drive that appeared to be having the most trouble.
I'm still slightly confused by some of the output of the other commands:
glabel status
gpart list
camcontrol devlist
The gpart list will long. You can cut out the part about ada0.
Yes, the tests run in the background and are internal to each drive. Any access to the drives will slow/pause the tests.
In a separate post, full output of the following for each disk:
smartctl -q noserial -a /dev/adaX
ghostlobster
OK...the family has left so I can get back to work on this. Here's what I've done. I've done a complete rebuild on the box, removed the IDE drive which was being used as the freenas OS install drive, and installed FreeNAS on a USB drive. The SATA data drives are probably all connected to different SATA ports on the mobo...honestly, as messed up as things were, I did not think it would have much of a bearing on the troubleshooting here.
I added another 4BG USB drive and shared it out as a CIFS share, just so I could get to the outputs of these commands easier, and don't run the risk of missing things with a copy and paste of screens using a |more command.
So...here's what I've got:
Glabel status:
                                                              Name  Status  Components
gptid/29ace990-0420-11e2-ba6f-000acd1fbb8d     N/A  ada0p2
gptid/35b37ca9-031e-11e2-b182-000acd1fbb8d     N/A  ada1p2
gptid/36a53dae-031e-11e2-b182-000acd1fbb8d     N/A  ada2p2
gptid/32ea520c-031e-11e2-b182-000acd1fbb8d     N/A  ada3p2
                             ufs/FreeNASs3     N/A  da0s3
                             ufs/FreeNASs4     N/A  da0s4
                            ufs/FreeNASs1a     N/A  da0s1a
                                ufs/output     N/A  da1p2
gpart list
Geom name: ada0
modified: false
state: OK
fwheads: 16
fwsectors: 63
last: 1953525134
first: 34
entries: 128
scheme: GPT
Providers:
1. Name: ada0p1
   Mediasize: 2147483648 (2.0G)
   Sectorsize: 512
   Stripesize: 0
   Stripeoffset: 65536
   Mode: r1w1e0
   rawuuid: 2997569c-0420-11e2-ba6f-000acd1fbb8d
   rawtype: 516e7cb5-6ecf-11d6-8ff8-00022d09712b
   label: (null)
   length: 2147483648
   offset: 65536
   type: freebsd-swap
   index: 1
   end: 4194431
   start: 128
2. Name: ada0p2
   Mediasize: 998057319936 (929G)
   Sectorsize: 512
   Stripesize: 0
   Stripeoffset: 2147549184
   Mode: r0w0e0
   rawuuid: 29ace990-0420-11e2-ba6f-000acd1fbb8d
   rawtype: 516e7cba-6ecf-11d6-8ff8-00022d09712b
   label: (null)
   length: 998057319936
   offset: 2147549184
   type: freebsd-zfs
   index: 2
   end: 1953525134
   start: 4194432
Consumers:
1. Name: ada0
   Mediasize: 1000204886016 (931G)
   Sectorsize: 512
   Mode: r1w1e1
Geom name: ada1
modified: false
state: OK
fwheads: 16
fwsectors: 63
last: 1953525134
first: 34
entries: 128
scheme: GPT
Providers:
1. Name: ada1p1
   Sectorsize: 512
   Stripesize: 0
   Stripeoffset: 65536
   Mode: r1w1e0
   rawuuid: 3594a100-031e-11e2-b182-000acd1fbb8d
   label: (null)
   length: 2147483648
   offset: 65536
   type: freebsd-swap
   index: 1
   end: 4194431
   start: 128
2. Name: ada1p2
   Sectorsize: 512
   Stripesize: 0
   Mode: r0w0e0
   rawuuid: 35b37ca9-031e-11e2-b182-000acd1fbb8d
   label: (null)
   offset: 2147549184
   type: freebsd-zfs
   index: 2
   end: 1953525134
   start: 4194432
Consumers:
1. Name: ada1
   Sectorsize: 512
   Mode: r1w1e1
Geom name: ada2
modified: false
state: OK
fwheads: 16
fwsectors: 63
last: 1953525134
first: 34
entries: 128
scheme: GPT
Providers:
1. Name: ada2p1
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r1w1e0
   rawuuid: 3680e0f9-031e-11e2-b182-000acd1fbb8d
   label: (null)
   length: 2147483648
   offset: 65536
   type: freebsd-swap
   index: 1
   end: 4194431
   start: 128
2. Name: ada2p2
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r0w0e0
   rawuuid: 36a53dae-031e-11e2-b182-000acd1fbb8d
   label: (null)
   offset: 2147549184
   type: freebsd-zfs
   index: 2
   end: 1953525134
   start: 4194432
Consumers:
1. Name: ada2
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r1w1e1
Geom name: ada3
modified: false
state: OK
fwheads: 16
fwsectors: 63
last: 1953525134
first: 34
entries: 128
scheme: GPT
Providers:
1. Name: ada3p1
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r1w1e0
   rawuuid: 32ac0871-031e-11e2-b182-000acd1fbb8d
   label: (null)
   length: 2147483648
   offset: 65536
   type: freebsd-swap
   index: 1
   end: 4194431
   start: 128
2. Name: ada3p2
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r0w0e0
   rawuuid: 32ea520c-031e-11e2-b182-000acd1fbb8d
   label: (null)
   offset: 2147549184
   type: freebsd-zfs
   index: 2
   end: 1953525134
   start: 4194432
Consumers:
1. Name: ada3
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r1w1e1
Geom name: da0
modified: false
state: OK
fwheads: 255
fwsectors: 63
last: 4050943
first: 63
entries: 4
scheme: MBR
Providers:
1. Name: da0s1
   Mediasize: 988291584 (942M)
   Sectorsize: 512
   Stripesize: 0
   Stripeoffset: 32256
   Mode: r1w0e1
   attrib: active
   rawtype: 165
   length: 988291584
   offset: 32256
   type: freebsd
   index: 1
   end: 1930319
   start: 63
2. Name: da0s2
   Sectorsize: 512
   Stripesize: 0
   Stripeoffset: 988356096
   Mode: r0w0e0
   rawtype: 165
   length: 988291584
   offset: 988356096
   type: freebsd
   index: 2
   end: 3860639
   start: 1930383
3. Name: da0s3
   Mediasize: 1548288 (1.5M)
   Sectorsize: 512
   Stripesize: 0
   Stripeoffset: 1976647680
   Mode: r0w0e0
   rawtype: 165
   length: 1548288
   offset: 1976647680
   type: freebsd
   index: 3
   end: 3863663
   start: 3860640
4. Name: da0s4
   Mediasize: 21159936 (20M)
   Sectorsize: 512
   Stripesize: 0
   Stripeoffset: 1978195968
   Mode: r1w1e2
   rawtype: 165
   length: 21159936
   offset: 1978195968
   type: freebsd
   index: 4
   end: 3904991
   start: 3863664
Consumers:
1. Name: da0
   Mediasize: 2074083328 (2G)
   Sectorsize: 512
   Mode: r2w1e4
Geom name: da0s1
modified: false
state: OK
fwheads: 255
fwsectors: 63
last: 1930256
first: 0
entries: 8
scheme: BSD
Providers:
1. Name: da0s1a
   Mediasize: 988283392 (942M)
   Sectorsize: 512
   Stripesize: 0
   Stripeoffset: 40448
   Mode: r1w0e1
   rawtype: 0
   length: 988283392
   offset: 8192
   type: !0
   index: 1
   end: 1930256
   start: 16
Consumers:
1. Name: da0s1
   Sectorsize: 512
   Stripesize: 0
   Stripeoffset: 32256
   Mode: r1w0e1
Geom name: da1
modified: false
state: OK
fwheads: 255
fwsectors: 63
last: 7669790
first: 34
entries: 128
scheme: GPT
Providers:
1. Name: da1p1
   Sectorsize: 512
   Stripesize: 0
   Stripeoffset: 65536
   Mode: r1w1e0
   rawuuid: af4a6a70-17d4-11e2-95dd-001617ec2159
   label: (null)
   length: 2147483648
   offset: 65536
   type: freebsd-swap
   index: 1
   end: 4194431
   start: 128
2. Name: da1p2
   Mediasize: 1779383808 (1.7G)
   Sectorsize: 512
   Stripesize: 0
   Mode: r1w1e2
   rawuuid: af86620d-17d4-11e2-95dd-001617ec2159
   rawtype: 516e7cb6-6ecf-11d6-8ff8-00022d09712b
   label: (null)
   length: 1779383808
   offset: 2147549184
   type: freebsd-ufs
   index: 2
   end: 7669790
   start: 4194432
Consumers:
1. Name: da1
   Mediasize: 3926949888 (3.7G)
   Sectorsize: 512
   Mode: r2w2e4
camcontrol devlist
<HP DVD Writer 640b E152>          at scbus0 target 0 lun 0 (pass0,cd0)
<ST31000528AS CC46>                at scbus2 target 0 lun 0 (pass1,ada0)
<ST31000520AS CC32>                at scbus3 target 0 lun 0 (pass2,ada1)
<ST1000DM003-9YN162 CC4B>          at scbus4 target 0 lun 0 (pass3,ada2)
<ST1000DL002-9TT153 CC32>          at scbus5 target 0 lun 0 (pass4,ada3)
< MIMOBOT 8.07>                    at scbus8 target 0 lun 0 (pass5,da0)
<Kingston DataTraveler G3 PMAP>    at scbus9 target 0 lun 0 (da1,pass6)
smartctl output coming in next post
ghostlobster
smartctl -q noserial -a /dev/adax:
Ada0:
Model Family:     Seagate Barracuda 7200.12
Device Model:     ST31000528AS
Firmware Version: CC46
User Capacity:    1,000,204,886,016 bytes [1.00 TB]
Sector Size:      512 bytes logical/physical
ATA Version is:   8
ATA Standard is:  ATA-8-ACS revision 4
Local Time is:    Tue Oct 16 14:17:44 2012 PDT
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x82)	Offline data collection activity
					was completed without error.
Self-test execution status:      (   0)	The previous self-test routine completed
					been run.
data collection: 		(  600) seconds.
capabilities: 			 (0x7b) SMART execute Offline immediate.
					command.
					Self-test supported.
SMART capabilities:            (0x0003)	Saves SMART data before entering
					power-saving mode.
Error logging capability:        (0x01)	Error logging supported.
Short self-test routine
recommended polling time: 	 (   1) minutes.
recommended polling time: 	 ( 176) minutes.
Conveyance self-test routine
recommended polling time: 	 (   2) minutes.
SCT capabilities: 	       (0x103f)	SCT Status supported.
					SCT Data Table supported.
  1 Raw_Read_Error_Rate     0x000f   104   099   006    Pre-fail  Always       -       7289736
  3 Spin_Up_Time            0x0003   096   095   000    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   100   100   020    Old_age   Always       -       142
  5 Reallocated_Sector_Ct   0x0033   100   100   036    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x000f   064   060   030    Pre-fail  Always       -       3117785
  9 Power_On_Hours          0x0032   099   099   000    Old_age   Always       -       1096
 10 Spin_Retry_Count        0x0013   100   100   097    Pre-fail  Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       71
183 Runtime_Bad_Block       0x0032   100   100   000    Old_age   Always       -       0
184 End-to-End_Error        0x0032   100   100   099    Old_age   Always       -       0
187 Reported_Uncorrect      0x0032   100   100   000    Old_age   Always       -       0
188 Command_Timeout         0x0032   100   100   000    Old_age   Always       -       0
189 High_Fly_Writes         0x003a   100   100   000    Old_age   Always       -       0
190 Airflow_Temperature_Cel 0x0022   063   048   045    Old_age   Always       -       37 (Min/Max 22/37)
194 Temperature_Celsius     0x0022   037   052   000    Old_age   Always       -       37 (0 21 0 0 0)
195 Hardware_ECC_Recovered  0x001a   016   011   000    Old_age   Always       -       7289736
197 Current_Pending_Sector  0x0012   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0010   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x003e   200   200   000    Old_age   Always       -       9
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       38371237823724
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       1809558843
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       1320786376
SMART Error Log Version: 1
No Errors Logged
# 1  Extended offline    Completed without error       00%      1044         -
ADA1
Model Family:     Seagate Barracuda LP
Device Model:     ST31000520AS
Firmware Version: CC32
ATA Version is:   8
Local Time is:    Tue Oct 16 14:19:13 2012 PDT
					been run.
data collection: 		(  623) seconds.
					command.
					power-saving mode.
recommended polling time: 	 ( 222) minutes.
  1 Raw_Read_Error_Rate     0x000f   109   099   006    Pre-fail  Always       -       25005601
  4 Start_Stop_Count        0x0032   100   100   020    Old_age   Always       -       250
  7 Seek_Error_Rate         0x000f   073   060   030    Pre-fail  Always       -       24943224
  9 Power_On_Hours          0x0032   091   091   000    Old_age   Always       -       8316
 12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       125
183 Runtime_Bad_Block       0x0032   099   099   000    Old_age   Always       -       1
190 Airflow_Temperature_Cel 0x0022   063   056   045    Old_age   Always       -       37 (Min/Max 24/37)
194 Temperature_Celsius     0x0022   037   044   000    Old_age   Always       -       37 (0 22 0 0 0)
195 Hardware_ECC_Recovered  0x001a   022   022   000    Old_age   Always       -       25005601
199 UDMA_CRC_Error_Count    0x003e   200   199   000    Old_age   Always       -       30
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       218734094459264
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       355260543
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       218645175
No Errors Logged
# 1  Extended offline    Completed without error       00%      8264         -
ADA2
Model Family:     Seagate Barracuda (SATA 3Gb/s, 4K Sectors)
Device Model:     ST1000DM003-9YN162
Firmware Version: CC4B
ATA Version is:   8
Local Time is:    Tue Oct 16 14:19:55 2012 PDT
					been run.
data collection: 		(  575) seconds.
					command.
					power-saving mode.
recommended polling time: 	 ( 110) minutes.
SCT capabilities: 	       (0x3085)	SCT Status supported.
  1 Raw_Read_Error_Rate     0x000f   113   099   006    Pre-fail  Always       -       53023288
  3 Spin_Up_Time            0x0003   097   096   000    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   100   100   020    Old_age   Always       -       53
  7 Seek_Error_Rate         0x000f   069   060   030    Pre-fail  Always       -       7706616
  9 Power_On_Hours          0x0032   100   100   000    Old_age   Always       -       600
 12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       53
190 Airflow_Temperature_Cel 0x0022   065   049   045    Old_age   Always       -       35 (Min/Max 23/35)
191 G-Sense_Error_Rate      0x0032   100   100   000    Old_age   Always       -       0
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       30
193 Load_Cycle_Count        0x0032   099   099   000    Old_age   Always       -       2392
194 Temperature_Celsius     0x0022   035   051   000    Old_age   Always       -       35 (0 22 0 0 0)
199 UDMA_CRC_Error_Count    0x003e   200   200   000    Old_age   Always       -       0
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       215731912311223
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       319783093330
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       74702224323
No Errors Logged
# 1  Extended offline    Completed without error       00%       550         -
ADA3
Model Family:     Seagate Barracuda Green (Adv. Format)
Device Model:     ST1000DL002-9TT153
ATA Version is:   8
Local Time is:    Tue Oct 16 14:20:32 2012 PDT
					been run.
					command.
					power-saving mode.
recommended polling time: 	 ( 179) minutes.
SCT capabilities: 	       (0x30b7)	SCT Status supported.
  1 Raw_Read_Error_Rate     0x000f   108   099   006    Pre-fail  Always       -       16192904
  3 Spin_Up_Time            0x0003   093   092   000    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   100   100   020    Old_age   Always       -       609
  7 Seek_Error_Rate         0x000f   067   060   030    Pre-fail  Always       -       6107173
  9 Power_On_Hours          0x0032   092   092   000    Old_age   Always       -       7391
 12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       597
188 Command_Timeout         0x0032   100   099   000    Old_age   Always       -       4295032834
190 Airflow_Temperature_Cel 0x0022   062   053   045    Old_age   Always       -       38 (Min/Max 24/38)
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       78
193 Load_Cycle_Count        0x0032   100   100   000    Old_age   Always       -       613
194 Temperature_Celsius     0x0022   038   047   000    Old_age   Always       -       38 (0 13 0 0 0)
195 Hardware_ECC_Recovered  0x001a   012   005   000    Old_age   Always       -       16192904
199 UDMA_CRC_Error_Count    0x003e   200   195   000    Old_age   Always       -       12
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       241132348906756
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       3043770790
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       1619330349
No Errors Logged
# 1  Extended offline    Completed without error       00%      7339         -
ghostlobster
OK...when I get bored, I'm dangerous. I shutdown and flipped the disks on ada0 and ada1 (ada0 is now ada1). I did a zpool import and it's now returning this:
   pool: RAID
  state: UNAVAIL
 status: The pool was last accessed by another system.
   see: http://www.sun.com/msg/ZFS-8000-EY
	RAID                      UNAVAIL  insufficient replicas
	  raidz1-0                UNAVAIL  insufficient replicas
	    4140409436293275748   UNAVAIL  cannot open
	    13949890047348135266  UNAVAIL  cannot open
	    12864383027183141833  UNAVAIL  cannot open
	  14728624880139133829    UNAVAIL  cannot open
Weird! Is there any way to just tell it to rebuild whatever it uses to index the disks and grab whatever I can from these disks? Still, there is nothing in the /data/zfs directory.
paleoN
Since the disks names swapped, after a Factory Restore an updated:
zpool import
zdb -ll /dev/ada1p2
And stop swapping disks around. If you keep changing the disks then use a live CD/USB so you always start with a clean slate.
199 UDMA_CRC_Error_Count has increased on 3 of your drives. These indicate a hardware-level problem between the host controller and the controller chip on the drive. Look for common components, i.e. cables or the controller.
ghostlobster
zpool import output is above in my reply above yours.
zdb outputs here:
ADA0P2:
LABEL 0
    version: 28
    state: 0
    txg: 192838
    hostid: 1362761028
    vdev_children: 2
    vdev_tree:
        type: 'raidz'
        nparity: 1
        metaslab_array: 23
        metaslab_shift: 31
        ashift: 9
        is_log: 0
        children[0]:
            type: 'disk'
            whole_disk: 0
            DTL: 54
        children[1]:
            type: 'disk'
            whole_disk: 0
        children[2]:
            type: 'disk'
            whole_disk: 0
LABEL 1
    version: 28
    state: 0
    txg: 192838
    hostid: 1362761028
    vdev_children: 2
    vdev_tree:
        type: 'raidz'
        nparity: 1
        metaslab_array: 23
        metaslab_shift: 31
        ashift: 9
        is_log: 0
        children[0]:
            type: 'disk'
            whole_disk: 0
            DTL: 54
        children[1]:
            type: 'disk'
            whole_disk: 0
        children[2]:
            type: 'disk'
            whole_disk: 0
LABEL 2
    version: 28
    state: 0
    txg: 192838
    hostid: 1362761028
    vdev_children: 2
    vdev_tree:
        type: 'raidz'
        nparity: 1
        metaslab_array: 23
        metaslab_shift: 31
        ashift: 9
        is_log: 0
        children[0]:
            type: 'disk'
            whole_disk: 0
            DTL: 54
        children[1]:
            type: 'disk'
            whole_disk: 0
        children[2]:
            type: 'disk'
            whole_disk: 0
LABEL 3
    version: 28
    state: 0
    txg: 192838
    hostid: 1362761028
    vdev_children: 2
    vdev_tree:
        type: 'raidz'
        nparity: 1
        metaslab_array: 23
        metaslab_shift: 31
        ashift: 9
        is_log: 0
        children[0]:
            type: 'disk'
            whole_disk: 0
            DTL: 54
        children[1]:
            type: 'disk'
            whole_disk: 0
        children[2]:
            type: 'disk'
            whole_disk: 0
ADA1P2 here...major issue here I think!
LABEL 0
    version: 28
    state: 0
    txg: 192838
    hostid: 1362761028
    vdev_children: 2
    vdev_tree:
        type: 'disk'
        whole_disk: 0
        metaslab_array: 742
        metaslab_shift: 30
        ashift: 9
        asize: 998052462592
        is_log: 0
LABEL 1
    version: 28
    state: 0
    txg: 192838
    hostid: 1362761028
    vdev_children: 2
    vdev_tree:
        type: 'disk'
        whole_disk: 0
        metaslab_array: 742
        metaslab_shift: 30
        ashift: 9
        asize: 998052462592
        is_log: 0
LABEL 2
LABEL 3
ADA2P2
LABEL 0
    version: 28
    state: 0
    txg: 192838
    hostid: 1362761028
    vdev_children: 2
    vdev_tree:
        type: 'raidz'
        nparity: 1
        metaslab_array: 23
        metaslab_shift: 31
        ashift: 9
        is_log: 0
        children[0]:
            type: 'disk'
            whole_disk: 0
            DTL: 54
        children[1]:
            type: 'disk'
            whole_disk: 0
        children[2]:
            type: 'disk'
            whole_disk: 0
LABEL 1
    version: 28
    state: 0
    txg: 192838
    hostid: 1362761028
    vdev_children: 2
    vdev_tree:
        type: 'raidz'
        nparity: 1
        metaslab_array: 23
        metaslab_shift: 31
        ashift: 9
        is_log: 0
        children[0]:
            type: 'disk'
            whole_disk: 0
            DTL: 54
        children[1]:
            type: 'disk'
            whole_disk: 0
        children[2]:
            type: 'disk'
            whole_disk: 0
LABEL 2
    version: 28
    state: 0
    txg: 192838
    hostid: 1362761028
    vdev_children: 2
    vdev_tree:
        type: 'raidz'
        nparity: 1
        metaslab_array: 23
        metaslab_shift: 31
        ashift: 9
        is_log: 0
        children[0]:
            type: 'disk'
            whole_disk: 0
            DTL: 54
        children[1]:
            type: 'disk'
            whole_disk: 0
        children[2]:
            type: 'disk'
            whole_disk: 0
LABEL 3
    version: 28
    state: 0
    txg: 192838
    hostid: 1362761028
    vdev_children: 2
    vdev_tree:
        type: 'raidz'
        nparity: 1
        metaslab_array: 23
        metaslab_shift: 31
        ashift: 9
        is_log: 0
        children[0]:
            type: 'disk'
            whole_disk: 0
            DTL: 54
        children[1]:
            type: 'disk'
            whole_disk: 0
        children[2]:
            type: 'disk'
            whole_disk: 0
ADA3P2
LABEL 0
    version: 28
    state: 0
    txg: 192838
    hostid: 1362761028
    vdev_children: 2
    vdev_tree:
        type: 'raidz'
        nparity: 1
        metaslab_array: 23
        metaslab_shift: 31
        ashift: 9
        is_log: 0
        children[0]:
            type: 'disk'
            whole_disk: 0
            DTL: 54
        children[1]:
            type: 'disk'
            whole_disk: 0
        children[2]:
            type: 'disk'
            whole_disk: 0
LABEL 1
    version: 28
    state: 0
    txg: 192838
    hostid: 1362761028
    vdev_children: 2
    vdev_tree:
        type: 'raidz'
        nparity: 1
        metaslab_array: 23
        metaslab_shift: 31
        ashift: 9
        is_log: 0
        children[0]:
            type: 'disk'
            whole_disk: 0
            DTL: 54
        children[1]:
            type: 'disk'
            whole_disk: 0
        children[2]:
            type: 'disk'
            whole_disk: 0
LABEL 2
    version: 28
    state: 0
    txg: 192838
    hostid: 1362761028
    vdev_children: 2
    vdev_tree:
        type: 'raidz'
        nparity: 1
        metaslab_array: 23
        metaslab_shift: 31
        ashift: 9
        is_log: 0
        children[0]:
            type: 'disk'
            whole_disk: 0
            DTL: 54
        children[1]:
            type: 'disk'
            whole_disk: 0
        children[2]:
            type: 'disk'
            whole_disk: 0
LABEL 3
    version: 28
    state: 0
    txg: 192838
    hostid: 1362761028
    vdev_children: 2
    vdev_tree:
        type: 'raidz'
        nparity: 1
        metaslab_array: 23
        metaslab_shift: 31
        ashift: 9
        is_log: 0
        children[0]:
            type: 'disk'
            whole_disk: 0
            DTL: 54
        children[1]:
            type: 'disk'
            whole_disk: 0
        children[2]:
            type: 'disk'
            whole_disk: 0
I have another 1TB drive here...brand new. Would it be beneficial to do a complete copy of ADA2, using a raw copy utility?
ghostlobster
Sorry about complicvating things by swapping around, as well. I actually pulled the entire drive rack from this system and slapped it into another one just to see if the damn thing would import on another box with another controller, processor, RAM, cables and everything. No dice.
That was when I installed RC1 on a USB stick and put them back in the other system.
I'll leave them alone in that box until it's time to throw up the hands and just wipe is and rebuild the box, saying goodbye to the data...I am just realloy hoping that there is someway to retrieve at least some of the data here, though.
ghostlobster
Well...another interesting tidbit here. I booted from a FreeBSD 9 CD, and did a zpool import -FXfn RAID on it, just to see what it would return. The -n option tells it to just see if it'll work, without making any real changes., This test returned the following:
Would be able to return RAID to its state as of Friday October 12th (timestamp of around noonish). Woul discard appromimately 5 seconds of transactions.
Thoughts?
If I run that command and then form within that FreeBSD boot, do a zpool export RAID , would I then be able to import it to the FreeNAS setup and snag some of my data back?
paleoN
I don't think it will help anything. The drive itself appears OK, aside from the CRC errors. Which given they are happening to 2 other drives as well suggests faulty cables, faulty SATA ports or dusty ones, faulty controller or even faulty PSU.
paleoN
Thoughts?
I would try without the X to begin with & read only:
zpool import -fF -R /mnt -o rdonly=on RAID
I would also use different SATA cables before hand.
