Background
Hardware:
* Supermicro X7SBL-LN2
* 8GB RAM
* CPU Q6700 @ 2.66GHz
* 850w PSU
* 5 x WD Green 3TB drives
I don't know the version of "FreeNAS" 8 it is currently running but here is uname output
Server has been running FreeNAS 8 for years. The thumb drive it is installed on seems to be dieing -- serious file corruption on /, the web interface is permanently dead. Time for a clean install of the latest version.
Tho the web interface is dead, the server itself it fairly stable. No problems with reboots, only the occasional lockup on heavy writes as documented in bug #1310.
Process
I start by downloading FreeNAS-9.2.1.5-RELEASE-x64.img and writing it to a 16GB ADATA UV128 thumb drive. I have 2 of these, one for install files, one to install on to. Note these are USB3 and the server long predates USB3, this may be the cause of some of the problems, but not the reboots (they happen with no USB plugged in).
When booting off the install image flash drive the boot process starts, but it fails to mount root. The last notable error I see before the root mount failure is "intergrety check failed (da1,mbr)". Leaving it at the failed mount root screen for several minutes it will spontaneously reboot. Trying to manually mount root typically results in a kernel panic "panic: mountroot: unable to (re-)mount root."
After re-imaging the drive and trying again with the same result I move on to CD install.
I burn (with verify) FreeNAS-9.2.1.5-RELEASE-x64.iso and boot off it. It complains about some read errors during the boot process but eventually makes it to the install menu.
Problem
At this point I have 2 problems.
1. It shows my 16GB flash drive I plan to install onto as being 16k
2. If left at the install menu (idle), or working at the command-prompt, etc it will spontaneously reboot after several minutes.
I thought maybe the USB3 thumb drive was the problem, but the reboots happen even with no USB devices plugged in.
I ran a memtest overnight (around 10 hours). It found no problems and had no reboots. Does not reboot under freeNAS 8.
How do I proceed from here to get this diagnosed and fixed? Spontaneous reboots with no panic screen doesn't give me much to go on.
Hardware:
* 8GB RAM
* 850w PSU
FreeBSD 8.3-RELEASE-p5 #2 r244158M: Wed Dec 12 10:04:42 PST 2012
root@build.ixsystems.com:/home/jpaetzel/8.3.0/os-base/amd64/usr/home/jpaetzel/8.3.0/FreeBSD/src/sys/FREENAS.amd64 amd64Server has been running FreeNAS 8 for years. The thumb drive it is installed on seems to be dieing -- serious file corruption on /, the web interface is permanently dead. Time for a clean install of the latest version.
Process
Problem
