FreeNAS 8.2.0-RC1
J
jpaetzel
Guest
The development team is pleased to announce the availability of FreeNAS 8.2.0-RC1
https://sourceforge.net/projects/freenas/files/FreeNAS-8.2.0/RC1/
Release Notes for FreeNAS 8.2.0-RC1
*** IMPORTANT ***
- The GUI upgrade format changed in 8.2.0-BETA3 from xz to txz. What
this means is that if you are attempting to do a GUI upgrade to
8.2.0-RC1 from 8.2.0-BETA3 or 8.2.0-BETA4 use the .txz version of the GUI_Upgrade
file. If you are upgrading from any previous version use the .xz file.
- The image size increased in 8.0.1-BETA3. The new size requires a 2 GB
storage device. The GUI upgrade can be used to upgrade a system from
BETA3, BETA4, or RC1 but upgrades from earlier releases can only be
done from the CD. The other option is to save the config, reinstall
the new version, then restore the config.
- FreeBSD can be really touchy with hardware. Please be sure to update
your BIOS/BMC firmware when upgrading / installing FreeNAS if you run
into OS hang issues. There have been cases identified where a BIOS
upgrade has fixed driver hangs, and/or other issues with FreeNAS; one
such example was with an Intel 82578DC motherboard, as noted in the
FreeNAS 8 forum thread titled "8.0.3-RELEASE coming soon..":
http://bit.ly/rq78Q3 , post # 70-88. Again, please only do this if you
experience booting / runtime issues, as some vendors don't test
FreeBSD interoperability as much as others between major firmware
releases.
- Previous builds were branded as i386/amd64 (32-bit and 64-bit
respectively). 8.0.3-RC1+ rebranded the architectures as x86 and x64,
respectively.
- 8.0.1 and 8.0.2 images advertised CIFS shares to Macs by default but
8.0.3 and later images don't advertise CIFS shares by default. If you
want to advertise CIFS shares in 8.0.3 and later, be sure to turn on
"Zeroconf" support in the CIFS global settings.
- Builds prior to 8.0.3-RELEASE with 'CIFS' didn't actually have AIO
(asynchronous I/O) enabled. So, if you experience performance
degradation after upgrading from prior versions of FreeNAS to
8.0.3-RELEASE or newer, turn off AIO or tune the AIO size from '1' to
something more reasonable (the new default in 8.0.3-RELEASE-p1 is 4096
or 4kB).
Changes in the 8.2 branch versus 8.0.x
Overview
The 8.2 branch of FreeNAS introduces many functional changes when
compared with the 8.0.x releases.
ZFS can be manipulated from the CLI, and changes for supported items
tracked by FreeNAS will be reflected in the GUI. zvols, datasets, and
entire volumes can be created, destroyed, or manipulated on the CLI and
will be propagated to the GUI.
The GUI now supports active-passive multipath capable hardware, which
targets mainly SAS drives on dual expander backplanes. Any multipath
capable devices that are detected will be placed in multipath units
which are then exposed to the GUI, and the parent devices will be
hidden.
Plugins are now available. Third party modules can be added to FreeNAS
which will persist across upgrades and can be manipulated and configured
from the GUI. Documentation on using and creating plugins is available
at http://doc.freenas.org/index.php/Plugins . BitTorrent,
DLNA/uPNP, and iTunes plugins are available as of this writing.
The GUI now includes a webshell, which allows you to access a root
shell from within a web browser.
The "Create Volume" modal was renamed to "Volume Manager". Extending
existing pools is more intuitive than it was previously; selecting
multiple disks for a storage volume is now done via a multiselect
widget instead of checkboxes to improve ease of use when creating
volumes.
ZFS volumes can now have periodic scrub tasks configured for them; the
default is set to 35 days to be consistent with the OS default.
An autotuning script is now available -- disabled by default. It sets
various tunables and sysctls based on system resources and components.
The predetermined values are exposed through the GUI from the Sysctls
and Tunables panes.
A newer web toolkit is used, which behaves better with modal dialogs
and more intuitively in general when compared with older versions.
It also has better browser compatibility, including compatibility with
Android / iOS mobile devices!
A more responsive service state detection mechanism was added to
improve FreeNAS interoperability in VM software (VMware, VirtualBox,
etc).
Errata
The plugin jail networking has been switched to VIMAGE, which
requires bridging the plugin jail with an external interface. On
systems with multiple interfaces there is currently no way to
specify which interface is used. The current system chooses the interface
with the default route.
Changes since 8.2.0-BETA4:
Enhancements
GUI
1. Add missing tree icons when addding/viewing ntp servers and tunables.
2. Added icons for mountpoints, plugins, shell, sysctls.
3. Add alert if jail ip is unreachable.
4. Add check and alert for non-optimal multipath states.
5. Simplify replication setup with button for target host key scan.
6. Added options for save debug.
7. Add HTTP error 404 redirection page.
OS/Third party
1. Create zpools using gptid instead of device names.
2. Include sudo in system.
3. Improvements to save debug.
4. Allow multiple rsyncs to run in parallel.
Plugins
1. Removed need to have pbi-manger installed to build PBIs.
Bugfixes
GUI
1. Fix for mounting filesystems with spaces in the name.
2. Fix issue with OAuth with http(s) ports.
3. Fix parsing of zpools with mixed striped disks and vdevs.
OS/Third party
1. Workaround for jails refusing to start when spaces are in filesystems names.
2. Make jails persist while inactive for running init commands.
3. Fix potential deadlock with LoR in IPv6 routing.
4. Fix ZFS auto import crash.
5. Fix lagg to work with bridged networking.
Plugins
1. Fix permissions for minidlna sudoers file.
2. Fix mindlna with https.
Changes since 8.2.0-BETA3:
Enhancements
GUI
1. Add functionality to upgrade the plugin jail.
2. Add functionality to upgrade plugins.
3. Shuffle around a number of plugin related items.
4. Switch the widget used for rsync extra options to one that allows
arbitrary length input.
5. Limit the path length used in mount points to what the OS will allow.
6. Fix tab completion in the webshell for chrome.
7. Warn that the root email address isn't configured when configuring
email.
8. Add the ability to switch the console locale through the GUI.
9. Log failed attempt to create automatic snapshots.
10. Add the ability to set up SMART tests on multiple disks
simultaneously.
11. Add a disk wipe feature.
12. Show datasets in tree menu.
OS/Third party
1. Add support for the qlogic 10Gbe ethernet driver.
2. Change JSON-RPC API to support versioning.
AFP
1. Add the ability to set the fperm and dperm in the GUI.
Samba
1. Update to Samba 3.6.5
Bugfixes
Middleware
1. Fix a bug that caused a traceback getting UFS volume status.
2. Improve logging for LDAP or AD integration.
3. Fix default clone path for Zvols.
4. Fix issue with jail install to keep the jail from being copied twice.
OS/Third party
1. Fix remote syslogging.
2. Fix basic/advanced view for forms.
3. Fix ataidle functionality.
4. Remove the arbitrary FTP passive port minimum.
5. Fix setting permissions from the GUI for UTF-8 filenames.
6. Fix UPS email notification.
7. Fix the defaults for the autotuner.
8. Fix database permissions/ownership.
GUI
1. Filter out multipath units from view disks screen.
2. Set the replication SSH port in the OS properly.
3. Fix webshell environment and locale.
4. Fix a bug that would leave ghost volumes on delete/export.
5. Fix bug in firmware upgrade.
Changes since 8.2.0-BETA2:
Enhancements
GUI
1. A major refactoring of the plugin structure has been done.
iSCSI
1. Target reload is now supported for adding and removing (but not changing)
targets on the fly. The Logical Unit Controller is used for this, reload
will not function if the LUC is not enabled.
CIFS
1. Samba has been upgraded to 3.6.4 to address the security issues in 3.6.3
Bugfixes
GUI
1. Fix a javascript error that affected IE8
Changes since 8.0.4-RELEASE:
Enhancements
Build
1. Refactoring of the build system was done to ease release
engineering and make FreeNAS software development easier, faster,
and more deterministic.
2. Plugin jail generation was integrated into the build system.
GUI
1. The current password box for changing the admin password is hidden
when there isn't an admin password set.
2. Adding users allows for placing users into additional groups, as well
as greater clarity about the primary group the user will be in.
3. The NTP configuration fields are split in to separate fields instead
of overloading a single field.
4. Create Volume is now renamed to Volume manager, and has a different
widget for selecting multiple disks, as well as a better GUI for
extending existing volumes versus adding new volumes.
5. Create dataset and create zvol are now buttons listed per pool, in
addition nested datasets can be created as a dataset has an add
dataset button.
6. Deleting volumes and datasets properly cascades to shares and
services; notification is provided if a filesystem is in use and
the configuration database is guaranteed to be more consistent with
the system state.
7. Update the GUI to reflect the fact that the dynamic DNS update period
is in seconds, not milliseconds.
8. Add the ability to enable or disable the autotuner to system ->
settings -> advanced.
9. Alias IPs are displayed in the interface configuration screen.
10. ZFS scrubs can be scheduled via the GUI.
11. The IP address used to connect to the FreeNAS box is displayed in
the GUI.
Middleware
1. Significant refactoring of the middleware was done to support
various changes made to the GUI.
OS/Third party
1. Add the iSCSI initiator kernel module to the system.
Plugins
AFP
CIFS
iSCSI
1. Use configured IPs on the system as candidates for portal addresses.
NFS
Tools
Bugfixes
Build
GUI
1. Exclude snapshots with existing clones from the pending delete list.
This fixes an issue where a clone will prevent an existing snapshot
from being deleted by the autosnapper.
2. Browser cache can become confused when the same browser is used to
access multiple versions of FreeNAS. Version specific cache data
was added to mitigate this issue.
Middleware
OS/Third party
Plugins
AFP
AD/CIFS/LDAP
1. Disable directory name caching, which improves performance on BSD.
2. Remove the ability to set a guest account per share, this is a global
setting only.
3. Change the default guest account to nobody.
4. Add anonymous LDAP bind support.
iSCSI
1. Ensure that a file extent resides in a volume.
NFS
Tools
Changes since 8.0.4-RC1:
Enhancements
GUI
1. Rename 'loaders' to 'tunables' to target the FreeBSD concept under
inspection (kernel tunables) (SF r10235, r10236).
Bugfixes
OS/Third party
1. Remove sane caps for minimum ZFS requirements for lower spec'ed home
user machines added in 8.0.4-BETA1. A better solution will be devised
in 8.2.0 with automatic system tuning, similar to legacy's
zfskerntune (SF r10271).
CIFS
1. Correct guest parameter setting in the GUI as it's a global option,
not a per-share option (SF r10296).
2. Allow Guest Only parameter only makes sense when Allow Guest is
specified (SF r10300).
3. Validate guest setting prior to accepting POST to ensure that the
value set for Guest is sane.
Changes since 8.0.4-BETA2:
Enhancements
Build
1. Remove Full_Install from the compressed disk image name to avoid
potential confusion when looking at the disk image vs the GUI
upgrade image (SF r10154).
Middleware
1. Do not restart collectd (reporting backend) when deleting snapshots
in the GUI (SF r10139).
Tools
1. Add arcstat.py and arc_summary.py tools originally contributed by
jhell (FreeBSD contributor), ported by jhixson to FreeNAS 8.x.
Bugfixes
GUI
1. Correct window title for snapshot deletion GUI (SF r10138).
Middleware
1. Catch ZFS snapshot errors when snapshots are done via the GUI instead of
failing silently (SF r10152).
2. Work around interoperability issues with user / group population in the
GUI by failing silently in certain cases if AD/LDAP users cannot be
retrieved (SF r10140).
3. Fix case where local and remote paths passed to rsync in Rsync tasks
weren't quoted, so paths with spaces in them would not work (FN 1285).
Changes since 8.0.4-BETA1:
Enhancements
OS/Third party
1. Update transmission to 2.42 (SF r10093).
2. Add MegaCLI tool (SF r10072, r10073).
3. Disable periodic tasks in the base system that would negatively
impact system performance on NAS boxes with large directory
structures (SF r10113).
Bugfixes
Middleware
1. Fix handling for 'every day' SMART tasks created in the GUI
(SF r10088).
2. Add in several robustness fixes to reduce potential for filesystem
corruption on root / boot device. In some scenarios this would also
improve performance when fetching data from the root device as well
(SF r10095, r10109, r10129).
CIFS
1. Fix vfs objects modules ordering so shadow copy (aka previous
versions) support functions again (FN 935, FN 1186, FN 1275).
2. Update samba to 3.6.3 to resolve several bugs (both security and
non-security related) (SF r10127).
iSCSI
1. Network field from iSCSI initiator could contain multiple IP
addresses, CIDR addresses, or ANY keyword (SF r10082).
2. Generate istgt.conf properly if and when multiple initiators were
specified (SF r10081).
Changes since 8.0.3-RELEASE-p1:
Enhancements
Build
1. Add .img suffix to simplify mounting full disk image for Windows and
OSX users (FN # 1236).
OS/Third party
1. Update firefly to 1696_6 for iTunes 10.5.2+ compatibility.
2. Add in sane caps for minimum ZFS requirements for lower spec'ed home
user machines.
AD/CIFS
1. Automatically create AD/LDAP user home directories (FN # 1203).
2. Add 'allow trusted domains' knob in the CIFS global configuration
(FN # 998).
iSCSI
1. Restrict portal input in the GUI to prevent scenarios where
incorrect input would prevent iSCSI from starting (FN # 1231).
Rsync
1. Add rsync+SSH functionality (FN # 990).
2. Add functionality to differentiate rsync pushing from pulling
(FN # 394).
Bugfixes
GUI
1. Fix disks / partition parsing when importing volumes (FN # 1202).
2. Restrict users from creating cronjobs / rsync tasks with long
usernames (FN # 1061).
Middleware
1. Correct smbpasswd parsing when debug level isn't set to minimum
logging (FN # 1224).
AD/CIFS
1. Escape samba AD/LDAP passwords (FN # 1225).
2. Ensure guest accounts are disabled if checked (SF r8276).
Changes since 8.0.3-RELEASE:
Enhancements
OS/Third party
1. Update ataidle from 2.6 to 2.72 based on maintainer's (brucec@FreeBSD)
recommendation due to interoperabilities with 2.6 and certain chipsets.
2. Fix the inadyn port so that it works on i386.
Bugfixes
Middleware
1. Fix a regression for DHCP users where /etc/resolv.conf would be nulled
out if DNS servers weren't specified in the GUI.
AD/CIFS
1. Disable AIO by default and change the default AIO read / write size to
4kB. This was done provided feedback and the fact that the build fixes
actually enabled AIO, whereas prior releases didn't enable it by
default. This can cause issues with machines that don't have the
resources to service AIO requests quickly enough, where previously they
would be able to service requests at near line speeds, whereas after
they are unable to service requests that quickly.
NFS:
1. Add in logic to start lockd and mountd when NFS is enabled s.t. FreeNAS
doesn't need to be manually prodded to start the services, or rebooted
in order for the services to become effective.
Changes since 8.0.2-RELEASE:
Enhancements
OS/Third party
1. Use smaller block and frag sizes for /etc and /var .
2. Import a build tweak to nuke /var/db/pkg to save ~7MB space.
3. Other build tweaks to remove non-essential features and packages from
the image.
4. Disable output to /var/log/console.log in non-debug builds to avoid
unnecessary duplication in /var/log/messages .
5. Upgrade ataidle to 2.6.
6. Upgrade nut / net-snmp to 2.6.2 and 5.7.1, respectively.
7. Import omnibus build system fixes to fix the fact that the 8.0.3-BETA1
image was broken due to the environment of the build machine where it
was produced on. This also fixes other items, such as DDNS because of
build environment tainting.
8. Increase the /var md size from 74MB to 160MB s.t. samba will be able
to service requests copying large sets of files, and the rest of the
system will be able to play nicely with samba to a certain degree.
More tuning is required for larger samba userbases.
GUI
1. Add kernel tunable / sysctl support.
Middleware
1. Hide Etc/GMT* timezones as they're behavior is counterintuitive and
conflicts with Windows 7 semantics (see r8707).
AD/CIFS
1. Bump samba from 3.5.11 to 3.6.1.
2. Address simple failure cases with getting Kerberos tickets (clock
skew) and joining AD domains (invalid passwords, bad short domain names,
etc) so that users could better rectify improperly configured NAS boxes;
this means that if either of these cases fail, the GUI will now inform
the user that the 'Active Directory' service is stopped.
3. Fix cachetool to better prevent potential race condition at boot between
winbindd and ix-cache.
4. Add knob for enabling/disabling Zeroconf/Bonjour (avahi) support in the
GUI. For technical reasons outside of the author's control, this
feature defaults to off when upgrading FreeNAS. FreeNAS admins
anticipating that they will have Mac users attempting to connect to CIFS
shares should enable this feature.
AFP
1. Bump netatalk to 2.2.1.
2. Add knob for controlling the maximum number of configurable connections
(see ticket: 847).
3. Only advertise services via avahi if they're enabled (see ticket: 852).
Rsync
- NFSv4 ACL support (see: r8375, r8414).
Bugfixes
OS/Third party
1. Fix NTFS volume imports.
GUI
1. ZFS volume deletion failed when trying to delete zvol with the name
'zvol'.
2. SSH pubkey saving was broken unless you manually add a newline to the
text box.
3. Fix traceback when trying to edit user if ssh public key was not
specified.
4. Fix the bug in rsync tasks where it would strip the trailing '/' off
the end of the destination path.
5. Fix a validation error when editing users / groups in 8.0.2+ where
if one entered in a path that wasn't valid, the GUI would traceback
instead of punting the actual validation error.
6. Fix an issue where if one entered in an invalid path, the GUI would
traceback instead of providing feedback stating that the directory
provided was invalid.
Middleware
1. Rsync task/crontab generation was broken with AD usernames and other
unsanitized input.
2. Fix email regressions since 8.0.2-RELEASE-p1 (SMART emails now work
with more than one recipient, non-SMTP authentication based emails
work again).
4. Fix an issue where if one autosnap process was killed uncleanly, more
autosnap processes could back up and eventually deadlock the system.
5. Fix an issue where the ZFS scrub cronjobs would execute every 30 days
instead of a number divisible by 7, so what would generally happen is
that ZFS scrubs would generally execute in the middle of the week.
6. Fix setting httpd to listen on an interface which is not the first
interface.
7. Add logic to create home directories on demand instead of failing
'silently' if the path to the directory didn't already exist.
8. Fix 'detaching' NTFS/UFS volumes so that it unmounts the volume in
the FreeBSD backend.
AD/CIFS
1. Change the default workgroup from FREENAS to WORKGROUP as having the same
name for the workgroup and the hostname is illegal per the SMB/CIFS
protocol.
Cosmetic items
1. Change "SSH key" in GUI to "SSH Public Key".
2. Fix GUI trademarks and branding to be more consistent with proper
branding, similar to what TrueNAS does today.
Major changes since 8.0.1-RELEASE:
- The email subsystem was not working correctly in 8.0.1-RELEASE, which
resulted in the system not being able to send mail, as well as of the
alerting system in the GUI.
Changes since 8.0.1-RELEASE:
- Allow decimal numbers for a dataset quota. (r8728)
- Fix setting recursive ACLs. (r8270)
- Start proftpd after ix-ssl to use the correct SSL cert. (r8246)
- Use wildcards in cron and rsync jobs instead of listing all values. (r8214, r8211)
- Fix case in iSCSI targets to match the behavior specified by RFC 3722. (r8120)
Changes since 8.0-RELEASE:
There's too much to list here, but the high points are:
- Divorced the volume members in the database from the FreeBSD devices.
This resolves an issue where FreeBSD can change devices names and the
GUI doesn't pick up the updates due to the devices names being hard-wired
in the database.
- Support exporting ZFS zvols (virtual devices) as device extents via iSCSI.
8.0 was only able to export physical device nodes or file based extents.
- The GUI now has an event notification system.
- The email backend has been refactored.
- Many many changes in the GUI to help it validate and sanitize inputs that
are passed to the backend daemons.
- Added UPS functionality.
- Added rsync client and server functionality.
- Added the ability to schedule cron jobs in the GUI.
- Vastly improved and reworked snapshot replication.
Errata:
- CHAP doesn't work with GlobalSAN initiators on OS X.
- Upgrades from FreeNAS 0.7 aren't supported.
- The installer doesn't check the size of the install media before attempting
an install. A 2 GB device is required, but the install will appear to
complete successfully on smaller devices, only to fail at boot.
- The installer will let you switch from i386 to amd64 architecture and
vice-versa, but some files, such as the rrd files used by the statistics
graphing package are architecture dependent.
- There are known interoperability issues with FreeNAS and Samba 4.x being
used as a PDC due to Samba 4.x not conforming to the Microsoft CIFS
specification and the way LDAP queries are executed on FreeNAS. Please see
the following support ticket for more details:
http://support.freenas.org/ticket/1135 .
Filename:
FreeNAS-8.2.0-RC1-x64.GUI_Upgrade.txz
SHA256 Hash:
3dc6ca50b2ee8105aebab34dd806e30e45b325afdfc7aee2311f38b5b7edcf8f
Filename:
FreeNAS-8.2.0-RC1-x64.GUI_Upgrade.xz
SHA256 Hash:
a11a96fa5617d70e69c936acf6819b53dc6a329a1015be34386b2c98dbf8a2fa
Filename:
FreeNAS-8.2.0-RC1-x64.img.xz
SHA256 Hash:
caf3c103773e74111c1555463bfd8a2c198b9e028ae1a517069b0978bf848e8f
Filename:
FreeNAS-8.2.0-RC1-x64.iso
SHA256 Hash:
c5d6787afeb7d8a20d925668e0548132e09990d2118d64bdd0839ceed88182ed
Filename:
FreeNAS-8.2.0-RC1-x86.GUI_Upgrade.txz
SHA256 Hash:
004cc7fc2deacd611659bd45eac5dfd79d6d259c11fd1a5ae609f9624dd7402e
Filename:
FreeNAS-8.2.0-RC1-x86.GUI_Upgrade.xz
SHA256 Hash:
071a93d6db20bfa235c2b9cf59d7e5c7e62a5457e85d2cc284301d6f768db8da
Filename:
FreeNAS-8.2.0-RC1-x86.img.xz
SHA256 Hash:
1b32c427ce997c0c82e0480c4af7892ca950f23db682e842a02bf2f7d8e73e43
Filename:
FreeNAS-8.2.0-RC1-x86.iso
SHA256 Hash:
e9368863fd316e502df294bc56208247cc6720cd7408bf9a328f666b3af10045
dfsooner
I will be interested to hear the results from those who have upgraded from FreeNAS-8.0.4-RELEASE-p3-x64 (11703).
I am always nervous about upgrades because I have a 48TB server and no possible way to back up all the data.
paleoN
Don't upgrade. In truth I don't know why anyone does! The data, zpool, isn't touched on an upgrade anyway as it's the same ZFS version.
  1. Buy a second USB stick
  2. Backup your configuration using System -> Settings -> General -> Save Config
  3. Install lastest and greatest to 2nd stick
  4. Restore your configuration using System -> Settings -> General -> Upload Config
If it doesn't work you simply swap back to your original stick and reboot.
bfishernc
Thanks for the post paleoN - that was my plan but LOVE seeing someone confirm the process. USB sticks are cheap and I'd happily use two for my FreeNAS environment (keep rotating sticks for each upgrade).
dfsooner
Makes perfect sense if ZFS is untouched. However, I thought there were some improvements in ZFS associated with 8.2 and that was my concern.
survive
Behold the Wumpus
Hi dfsooner,
No, that will be coming in FreeNAS 8.3, which will update the zfs version to 28.
-Will
ProtoSD
Can anyone else confirm that the CD upgrade from Beta-4 to RC-1 fails?
Here's a screenshot
colni
hi william,
As per this statement
i used the .txz file
Should i be using the .xz?
Grauniad
Hi, mine also failed. I have used the .txz file as advised.
Went through the update process as I have done previously, freenas rebooted but the GUI advises that the version is unchanged.
valesan
for me the upgrade from BETA4 with gui upgrade run correctly !
I removed the plugin jail, updated with the file .TXZ and then I reinstalled the new jail.
everything works fine, even miniDLNA!
colni
I didnt remove the jail perhaps that is something i missed on the documation?
garfunkel
The upgrade from Beta4 to RC1 failed for me too. I used the .tgz file. I eventually upgraded manually by saving the config, flashing the USB drive and loading the config in to /data manually (loading it in from the GUI also failed).
I have another issue which I've had with all 8.2 releases thus far. Apparently it's a known issue but I don't know what the status of it is. I have a HP Microserver N40L and it seems to run fine except for Transmission. I had Beta4 running very well and stable for a couple weeks with no issues until I tried to use Transmission. After a couple hours I got a Trap 12 error and the system hung. I rebooted. The machine then never fully boots and gets stuck at another Trap 12. The only way to fix it is to reflash the USB drive. RC1 still has this issue seemingly as my server has been running fine until I tried to use Transmission. About an hour in - Trap 12, same thing.
Now, from what I have gathered it seems to be a driver issue with the integrated NIC and it not liking the jail too much, particularly when the jail is shut down. I think Transmission must be crashing the Jail or something like that which is then causing the issue, and then on a reboot when the server tries to start it again the problem persists.
Is there any solution to this?, very annoying considering this is very common hardware, and not new. :( Other than that, the machine is solid.
Grauniad
I think what we are all saying here is that we are using this forum to report our findings/bugs - please don't take offence as we're not moaning, we value all the input and time you guys have spent on the development.
William Grzybowski
Great, but bugs are supposed to be reported in support.freenas.org, once confirmed.
colni
I think we should maybe move this report to the support tickets section, ill happily submit a ticket re the beta4 to RC1.
is there a troubleshooting section that gives me a how to so i can provide technical information for the team?
Oh it looks like william got in there before me!
EDIT: sorry i know this is the wrong forum but could you check the email confirmation token? ive request one for the support website but it has never arrived.
EDIT v2 : nevermind im just a dumb ass!
