I have a configured and working FreeNAS 1U certified storage device (purchased from iXSystems in 2019), that has been running well with dual 10GiE connections, and iSCSI shares. This device has had two iSCSI shares for several month now without issue.
I recently had a new requirement for storage, and configured two new ZVOLs on my zpool for the FreeNAS, and configured the ZVOLs for iSCSI following the pattern of my two other ZVOLs. Unfortunately, my ESXi hosts (there are 3) cannot connect to one of the two new devices.
On the ESXi side the 2 newly defined targets are visible, and show up in the list of available paths (seen using esxcli storage core path list), however the device does not show up in ESXi. On investigation in the vmkernel.log file shows errors registering a name to one of the two devices. Here's an excerpt of the log:
When I look closely at the FreeNAS iSCSI config under the Extends configuration, it shows that two of my devices were assigned the same Serial Number. Below there is a snippet of my /etc/ctl.conf file from my FreeNAS showing the extent definitions with the same ID.
Is this duplicate serial number the cause of the duplicate vml name that ESX is creating? Can I resolve this by modifying the serial number of the offending device?
Of course, any other suggestions are welcome!
2020-04-05T19:37:06.256Z cpu4:2099602 opID=e456f97e)VMWARE SCSI Id: Id for vmhba64:C0:T7:L0 0x62 0x34 0x39 0x36 0x39 0x31 0x34 0x36 0x64 0x32 0x30 0x34 0x30 0x31 0x00 0x00 0x69 0x53 0x43 0x53 0x49 0x20 2020-04-05T19:37:06.256Z cpu4:2099602 opID=e456f97e)ScsiUid: 435: Existing device naa.6589cfc0000002281ce7b4c311cdf6f2 already has uid vml.010000000062343936393134366432303430310000695343534920 2020-04-05T19:37:06.256Z cpu4:2099602 opID=e456f97e)ScsiDevice: 4925: Failing registration of device 'naa.6589cfc0000003d76064531dc405b977'
root@freenas[~]# cat /etc/ctl.conf
portal-group "default" {
portal-group "pg1" {
tag "0x0001"
discovery-filter "portal-name"
discovery-auth-group "no-authentication"
listen "192.168.2.4:3260"
listen "192.168.1.4:3260"
option "ha_shared" "on"
## Here's one of the two disks with duplicate serial -- this is the "new" one
lun "data_1" {
ctl-lun "4"
path "/dev/zvol/bmlfwbmfnasp01-zpool/data_1"
blocksize "512"
serial "b4969146d20401"
device-id "iSCSI Disk b4969146d20401 "
option "vendor" "FreeNAS"
option "product" "iSCSI Disk"
option "revision" "0123"
option "naa" "0x6589cfc0000003d76064531dc405b977"
option "pool-avail-threshold" "25508669764403"
option "rpm" "1"
lun "db_bk_1" {
ctl-lun "0"
path "/dev/zvol/bmlfwbmfnasp01-zpool/db_bk_1"
blocksize "512"
serial "b4969146d20400"
device-id "iSCSI Disk b4969146d20400 "
option "naa" "0x6589cfc000000df46582e219aef9e032"
option "rpm" "1"
## Here is the other of the two disks with duplicate serial -- this is the "old" one
lun "misc_bk_1" {
ctl-lun "1"
path "/dev/zvol/bmlfwbmfnasp01-zpool/misc_bk_1"
blocksize "512"
option "naa" "0x6589cfc0000002281ce7b4c311cdf6f2"
option "rpm" "1"
lun "os_1" {
ctl-lun "3"
path "/dev/zvol/bmlfwbmfnasp01-zpool/os_1"
blocksize "512"
serial "b4969146d20403"
device-id "iSCSI Disk b4969146d20403 "
option "naa" "0x6589cfc00000064fe57fe87af0ca57ee"
option "rpm" "1"
[snip]
