I can confirm this, also for U6.
HP Microserver Gen10.
smartctl returns all data es expected
root@freenas[~]# smartctl -a /dev/ada2
smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.2-STABLE amd64] (local build)
Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family: Western Digital Red
Device Model: WDC WD40EFRX-68N32N0
Serial Number: WD-xxxxxxxxxxx
LU WWN Device Id: 5 0014ee 21069ef1c
Firmware Version: 82.00A82
User Capacity: 4,000,787,030,016 bytes [4.00 TB]
Rotation Rate: 5400 rpm
Form Factor: 3.5 inches
ATA Version is: ACS-3 T13/2161-D revision 5
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Mon Oct 14 11:00:47 2019 CEST
SMART support is: Enabled
General SMART Values:
was never started.
been run.
data collection: (43740) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 464) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x303d) SCT Status supported.
SCT Data Table supported.
# 1 Short offline Completed without error 00% 6256 -
# 2 Short offline Completed without error 00% 6233 -
# 3 Short offline Completed without error 00% 6209 -
# 4 Short offline Completed without error 00% 6185 -
# 5 Short offline Completed without error 00% 6161 -
# 6 Short offline Completed without error 00% 6137 -
# 7 Short offline Completed without error 00% 6113 -
# 8 Short offline Completed without error 00% 6089 -
# 9 Short offline Completed without error 00% 6065 -
#10 Short offline Completed without error 00% 6041 -
#11 Short offline Completed without error 00% 6017 -
#12 Short offline Completed without error 00% 5993 -
#13 Short offline Completed without error 00% 5969 -
#14 Short offline Completed without error 00% 5945 -
#15 Short offline Completed without error 00% 5921 -
#16 Short offline Completed without error 00% 5897 -
#17 Short offline Completed without error 00% 5873 -
#18 Short offline Completed without error 00% 5849 -
#19 Short offline Completed without error 00% 5825 -
#20 Short offline Completed without error 00% 5801 -
#21 Short offline Completed without error 00% 5777 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
