FreeNAS 11.1-BETA1 Now Available
amiskell
Maybe this isn't the right place. But looking at tall the features etc. I do not see docker listed. Has this been pushed out of 11.1 now?
Thanks.
It's been pushed to 11.2 for now. Honestly, I wouldn't hold your breath for full docker support for some time.
Well, there are a few things to address there:
  • Switching between GUIs is already a thing, unfortunately. I understand that 11.2 should be essentially feature complete (I say essentially because something might slip through the cracks).
  • I don't expect the old GUI to be piped to work with iocage.
  • There will be a migration script from warden to iocage.
Hello
I have Installed 11.1 Prerelease version from 11.0 U4 but i have no menu as you can see in my picture
Can you help me please ?
File a bug report.
jclendineng
I mean the new gui has never worked for me honestly it just sits on "connecting to websocket" and I cannot upgrade because of all the issues listed here regarding manual and auto upgrades not working so I will reinstall using the iso provided. Maybe the 11.1 will fix the gui not working.
That's because something is blocking the connection. You need to fix that in your network.
The old UI is still the default.
SavageAUS
Tried to jump from the 11 stable to 11.1-PRERELEASE. Got thrown out of the wagon:
"You're not allowed to change away from the nightly train, it is considered a downgrade.
If you have an existing boot environment that uses that train, boot into it in order to upgrade that train."
Did you ever figure put how to switch to pre-release? I'm getting the same message.
Sent from my SM-G930F using Tapatalk
idachour
[root@freenas ~]# iocage --version
Version 0.9.10 RC
Version 0.9.10 RC
I have a workaround ... i just click "English" on the Dropdown list Language and all labels appeared
raidflex
Since iocage is still technically in beta, will we see a regular release cycle for FreeNAS to keep iocage up to date, at least until 1.0 is released?
The traditional model is to pull in updates in -Un releases for stuff if it's not prone to breakage and fixes specific issues.
appoli
Don't know if this is normal but I am getting regular posts in the log that the cache file /var/db/system/update doesn't have a sequence/can't be opened/doesn't exist. Not sure if this is normal?
File a bug report for that. At best, it's noise and noise is bad.
c_dog
You can force the update and to change the train by entering
freenas-update -v -T FreeNAS-11.1-PRERELEASE update
in the shell.
After updates are applied, you will need reboot to start up 11.1 beta1 on next boot. From there you should also be able to set the train to follow as FreeNAS-11.1-PRERELEASE in the future.
ThreeDee
So creating jails in the new UI is supposed to be using iocage and not warden? .. when I go to create a jail, once I got a warden error pop up .. if I successfully create a jail, they don't show up in the new UI but only in the old UI which means they are still using warden.. what am I doing wrong?
Are you using 11.1-BETA?
JJT211
Ive been meaning to wipe out and reinstall all my jails as they're from 9.2 and really been acting funky for a while. Now that this Beta has been released with iocage, is now the time I can finally make the jump without having to do it all over again at a future date?
ThreeDee
yes ..I'm using the 11.1-Beta1
I noticed the same; I created a jail in the new UI, but it turned out to be an warden jail. It is only visible in the old UI.
However, when I create a jail using iocage (via the command line), that jail does show up in the new UI (and not in the old). The new UI allows to start and stop that iocage jails, but that's pretty much it.
I'm not sure it that falls under "feature not yet complete" or "bug". :rolleyes:
Running jls from the command line works as expected and shows both jails.
appoli
Thank you for that info! I will do that today.
In addition in the daily security output file I got the following message from the kernel log file, should it be logged as well (and I’m assuming in a different bug?):
env: python: No such file or directory
Thanks!
adrianwi
Different types of jails created in different UIs? This sounds like a recipe for disaster?
