I am abit lost with scale. I just migrated from Core and I can't find a way to add LAN IPs to my apps. I have a few that need to run on VLANs and a few require LAN IPs. is there a way to force LAN DHCP on APPS ?
This will not help you for VLANs but using a reverse proxy in combination with local DNS entries usually works if you do not want access apps via their respective ports directly on the same IP.
well...I'm not sure this tutorial works on the TrueNAS-SCALE-23.10.1.3 anymore.
I'm stuck only with internal IPs.
is there another way to bridge lan dhcp?
my bad. sry for the lack of context. there are 2 things:
1. I can't find the MetaLB app
2. I can't add an additional interface to an app - the only interface/network configuration is enable/disable host network and change the port.
