As per title, I have jumped to a fresh install of FN11 (via FN9, Corral with 3-4 dockers, now FN11).  My aim is to get the dockers working again (URBackup, Nextcloud, possibly openproject)
FN working OK (probably needing tweaks for permissions but working)
I've installed Ubuntu 16.04 Server in a VM, done it several times so getting the hang of that! In 100Gb zvol
Installed docker in the Ubuntu VM, seems to be working OK (hello world and portainer working sort of)
Installed Portainer via docker. Once I got the hang of the right IP address can access that.
So I think it is coming together but its all a bit fragile (as is my confidence!!!)
My question mainly is how to do the storage generally
is 100Gb OK for Ubuntu as docker host (probably no more that 5-6 dockers over time)
I've set up a dataset of 1Tb for "datastore" where I anticipate I'll put all the media files etc in suitable folders
Main Q, how do I configure the ubuntu/docker host to access the "datastore" most efficiently?
This is all on a home network so permissions and security is not a particular concern/priority
Thanks
Thanks
