It's in the "unsupported" section in the OP.I'm running FreeNAS 11.2 and can't seem to find the detailed instructions for creating a SABnzbd jail.
i am having a lot of permission problems
i have to run this command to get it to automatically move and rename movies
iocage exec radarr chown -R rdarr:radarr /downloads/movies
basically give it permissions all over again to get it to work
yes and i have to do it every time to just it to workDid you run that command from the root of your Radarr jail? Did you only have to run it once?
What is the path to your movies on your FreeNAS system and what is the path to where your movies are downloaded to?yes and i have to do it every time to just it to work
i think i messed up permission somewhere along the line because now i can't even install a plugin
get this error
pkg-static: /var/db/pkg permissions (0777) too lax
i started fresh to clear all the permission issues i was having so now im back to the original problemWhat is the path to your movies on your FreeNAS system and what is the path to where your movies are downloaded to?
What about the paths in your Radarr jail?
Just updated to FreeNAS-11.2-U2 and none of my jails are accessible on the network. They are static IPs.
https://www.ixsystems.com/blog/library/freenas-11-2-u2/ said:To resolve this error when starting a plugin or jail or when installing a jail, click the 3 button menu for that jail, click Edit, click Network Properties, and change the vnet_default_interface property to “auto”. If that does not resolve the issue, try checking and unchecking the DHCP box.
Yeah same here. Thanks!This fixed the problem for me.
Do it manually. Otherwise you are tied to when/if they update the plugin instead of being able to stay up to date.I have a question regarding this guide. I am wondering if I could install the applications (e.g. transmission, radarr, sonarr) as plugins instead of manual jails and still be able to rest of this guide. Or is it better to use manual jails instead? What are the pros and cons of each way?
Thanks for your reply, in that case I will do it manually by following this guide. Biggest 'challenge' for me is to migrate all transmission torrents to this new transmission iocage jail :)Do it manually. Otherwise you are tied to when/if they update the plugin instead of being able to stay up to date.
sudo rsync -av --delete /mnt/tank/jails/transmission_1/var/db/transmission/ /mnt/tank/apps/transmission/transmission-home/Yeah rsync is great for this.Thanks for your reply, in that case I will do it manually by following this guide. Biggest 'challenge' for me is to migrate all transmission torrents to this new transmission iocage jail :)
edit: done!
Created new iocage jail for Transmission, used same data mount structure and user/group as in the Transmission warden jail. Copied config files from old to new jail:sudo rsync -av --delete /mnt/tank/jails/transmission_1/var/db/transmission/ /mnt/tank/apps/transmission/transmission-home/
Used a combination of this guide and https://gist.github.com/mow4cash/e2fd4991bd2b787ca407a355d134b0ff which is also based on this guide :)
iocage fstab -a plex /mnt/tank1/apps/plex /config nullfs rw 0 0Destination: /mnt/main/iocage/jails/plex/root/config does not exist!Try using this guide instead, this guide is based on the one we are discussing here but has more detailed steps and is therefore more ELI5 proof. It also includes setting up user/group/permissions so jails like Transmission, Sonarr & Radarr can work together properly. You can also do some steps in de UI instead of in de shell, for example creating the jails and the mount points. When you want to create a jail via UI be aware to do the 'advanced jail creation' and select all required options (e.g. vnet, allow_raw_sockets, autoboot).I updated from 9.10 today. Trying to follow this guide, but it assumes too much, or requires understanding I do not have. I'm trying to follow the directions for plex, but when i get to this step
I am getting errorDestination: /mnt/main/iocage/jails/plex/root/config does not exist!
My pool is named main not tank1, so I subbed that in (may be helpful to call that out in the guide). I created dataset apps and dataset plex inside that as is assumed with this, so not sure what I'm missing. I need some ELI5 instructions here, which these are not. Any help would be greatly appreciated.
Use a private tracker which doesn't allow RAR'ed content ;)Hey all, I've had Sonarr & SABnzbd working together nicely for a while, and now I've decided to add Transmission into the mix as a backup. I had no issues getting Sonarr, Jackett and Transmission working together, but after a successful download of a torrent from my private tracker, that's when I realized Sonarr doesn't unpack .rar files. So I've been trying to add an auto extract script to run after Transmission, and not having much luck finding a good guide that still works... a lot of the forum post I find are dead ends.
Can anyone advise me on scripts they use with transmission for automatic extraction?
