jgreco
Resident Grinch
- May 29, 2011
So I've set out to get my two LSI 9211-8i into the proper P20 IT firmware and I'm not sure if one of them (v5.00.13, slot 00) might already be messed up?
Looks like different outputs give me different information on whether it's already in IT or IR firmware. Which do I believe? Is the card bad?
IR is theoretically acceptable but performs more poorly because there's more code in the path. The IR firmware is supposed to function identically to the IT firmware aside from that. Nevertheless, you should get both of them set to IT phase 20.
