Over the last two days I've been working on rearchitecting my network. I'm configured multiple vLANs, setup a LAGG group for FreeNAS and am moving VMs and physical machines to the newly created vLANs. So far everything has gone relatively well. Today though I ran into the first issue that I haven't been able to solve. There is an issue transferring data between FreeNAS and any machine, physical or virtual, when they aren't on the same vLAN. At first I assumed that this was an issue with intra-vLAN routing and was the fault of pfSense. However I can transfer files between other machines that are in different vLANs without issue, just not FreeNAS. This seems to rule out routing as the issue.
When starting a transfer initially everything looks fine:
But then this will happen:
The speed drops to basically nothing, the transfer stalls. Eventually leading to this:
Hitting Try Again never succeeds. It will continue to die at the same point, within 1-2% every time:
If I do the transfer on the same vLAN it completes with no issues:
I've searched on all the topics I can think of but haven't been able to find anything that is similar. There's no new hardware involved. The FreeNAS box is physical with a Supermicro board, Intel NICs. The switch is a Cisco 3560. The pfSense box is also a physical box, also Supermicro/Intel. The VMs run on Supermicro blades with Intel NICs. My desktop is an ASUS board with Intel NIC. So there shouldn't be an issue with hardware. I'm at a total loss.
Network setup:
Network setup:
