Is it right to assume when you have made your zpool (Raidz1) you cannot add another disk to it?  Not without backing up all the data and destroying it and then making a new pool with the new disk included?
Also do you need to backup the contents of the usb drive your FreeNas installation is on? Just incase the USB drive one day gives up, would you lose your zpool and all your data? I ask as I have been messing about with different installations and wiping the usb drive each time and putting it back on there and it would never recognise there was a zpool already on my disks, so I'm guessing all the info about the zpool is on the usb drive - and if you lose that you lost all your data??
