Hi to all.
I had a look to freenas and use it over ethernet with dual 1gbe . Now I see the speed over ethernet is limited so I want try to boost performance, 10gbe look too much expensive so I will go with something like Fiber channel.
The setup will be freenas with fc card attached to vsphere (esxi) with another fc card. To low the price I think to go for 4gb fc card.
Someone know which cheap card can be used with freenas and vsphere (5.5U2)?
Thanks to all
Thanks to all
