Fast when striped, slow with anything else… CPU? [RESOLVED]
JCBone
Hi!
I have a TrueNAS Server with 8x 2TB WD Red EFXR. I had it configured as two 4 drive vdevs as Z1, combining to around 11TB.
The CPU is a i5-3470T CPU @ 2.90GHz, the Server has 8GB ECC Memory.
It always did well when accessed via Gigabit LAN, around 100MB/s as expected.
Now I've put a qnap 10Gbit/s card in there and connect to it via a 2,5Gbit/s USB Dongle.
It stays around 100MB/s when reading, around 220MB/s writing. Only if I destroy the Pool and set it up as a complete stripe I can saturate the 2,5Gbit/s.
So I guess it's NOT the drives or the controller, I suspect the CPU - but it just peaks around 50% in the dashboard if I hit the share with BM Disk Speed Test.
Using a SSD as a cache doesn't help anything.
Any suggestion for a strategy to find the bottleneck?
Thanks,
Jörg
-------- SOLUTION ---------
Well, it's been the controller. I changed it out for a controller with LSI 2008 chipset and flashed it to IT mode. Around 240MB/s read and write speed over 2.5 Gbit/s network.Thanks for all the suggestions!
Jörg
LarsR
get more ram, the new recommended amount is 16gb, 32 would be better.
JCBone
Hm. I've put non-ECC Ram in there for a test. The write speeds are more consistent now, but read still tops out at around 80MB/s
JCBone
Oh, I guess I missed something. This is another test with just a stripe over all 8 Drives, I only get around 100MB/s there, too. So what is the Problem? The controller is a AMCC 9650SE-8LP set to passthrough… maybe this?
Apollo
Your problem seems to be related to the understanding of the ZFS fundamentals. A stripe vedv doesn't give you performance benefit as would a true RAID controller.
If you really want to test your network throughput, exclude the pool form the equation and use iperf instead.
JCBone
Since I get consistent write speeds of around 250MB/s I guess my network throughput is fine. I'll try to get the controller out of the equation and test a single RaidZ1 vdev connected to the mainboard.
Patrick M. Hausen
Any single vdev will give you roughly the speed of a single disk. So a pair of mirrors will be roughly twice as fast as a 4-disk RAIDZ1. Best expected performance in your case would be 4 2-disk mirrors.
JCBone
yes, I already tested 4 2-disk mirrors with no effect. I really suspect the controller. Maybe I test 2 2-disk mirrors connected to the board.
JCBone
Maybe I could drop in one more drive and do a stripe over 3 3-disk RaidZ1 :smile: That should give me around 300MB/s.
JCBone
So… a striped mirror made of 4 disks attached to the mainboard DOES perform better. Around 150MB/s.
JCBone
Next Round. RaidZ1 made from 4 Disks attached to the mainboard. Still 150MB/s - so, lets see what happens when I stripe it with a second vdev.
JCBone
Just to be precise… iperf Test:
[ ID] Interval Transfer Bandwidth
[ 1] 0.00-10.01 sec 2804 MBytes 2349 Mbits/sec
So the network runs adequately.
JCBone
So, let's put the controller to work. I configured a hardware Raid6 over all 8 disks. Let's see what the performance will be, once it finishes it's "resilvering".
Samuel Tai
Please don't do that. You'll lose data.
JCBone
*sigh* - ok. And if I try a plain old Linux Distro on top of that? I just need a fast-ish network connected Storage for ONE client.
JCBone
The controller runs in JBOD mode, maybe there is a HBA firmware for it? I'm really running out of ideas here. Performance via the on board controllers wasn't much better… new mainboard, maybe? Another controller card?
Samuel Tai
Striped SSDs connected to the motherboard SATA ports will always be the fastest option.
JCBone
Surely, but I only need around 250MB/s… and I do have all those drives…
JCBone
What do you know. Problem Solved. removed my TrueNAS core bootdrive and installs a fresh copy of TrueNAS scale. Badabing. One Pool with two RaidZ vdevs. I guess I'll some other configs, too. Rock solid 250MB/s.
JCBone
All the drives in one RaidZ2 video offers less write, but read is still ok. Is resilvering a 4 drive vdev too risky? I once heard you should user RaidZ2 with more than six drives… and mine are just 2TB per drive.
