Alright, I am home and here is what I'm getting:
[root@freenas] ~# zpool status
  pool: Prometheus
state: DEGRADED
status: One or more devices has been removed by the administrator.
    Sufficient replicas exist for the pool to continue functioning in a
    degraded state.
action: Online the device using 'zpool online' or replace the device with
    'zpool replace'.
  scan: scrub repaired 0 in 11h50m with 0 errors on Mon Sep  1 15:50:18 2014
    Prometheus                                      DEGRADED     0     0     0
      raidz2-0                                      DEGRADED     0     0     0
        gptid/1e034043-dd70-11e3-9986-00259086bb62  ONLINE       0     0     0
        2439661819405573937                         REMOVED      0     0     0  was /dev/gptid/1e5432b0-dd70-11e3-9986-00259086bb62
        gptid/e3ea2fe7-f28f-11e3-9160-00259086c7b6  ONLINE       0     0     0
        gptid/1ef9fa71-dd70-11e3-9986-00259086bb62  ONLINE       0     0     0
        gptid/1f4f07be-dd70-11e3-9986-00259086bb62  ONLINE       0     0     0
        gptid/1fa0a862-dd70-11e3-9986-00259086bb62  ONLINE       0     0     0
errors: No known data errors
[root@freenas] ~# smartctl -a /dev/ada0
smartctl 6.2 2013-07-26 r3841 [FreeBSD 9.2-RELEASE-p10 amd64] (local build)
Copyright (C) 2002-13, Bruce Allen, Christian Franke, www.smartmontools.org
/dev/ada0: No such file or directory
Please specify device type with the -d option.
Use smartctl -h to get a usage summary
[root@freenas] ~#
So, I rebooted, and everything is reporting healthy:
  pool: Prometheus
state: ONLINE
  scan: resilvered 102M in 0h0m with 0 errors on Mon Sep  8 19:12:45 2014
    Prometheus                                      ONLINE       0     0     0
      raidz2-0                                      ONLINE       0     0     0
        gptid/1e5432b0-dd70-11e3-9986-00259086bb62  ONLINE       0     0     0
[root@freenas] ~#
Model Family:     Western Digital Red (AF)
Device Model:     WDC WD30EFRX-68EUZN0
Serial Number:
LU WWN Device Id: 5 0014ee 003cc9e65
Firmware Version: 80.00A80
User Capacity:    3,000,592,982,016 bytes [3.00 TB]
Rotation Rate:    5400 rpm
ATA Version is:   ACS-2 (minor revision not indicated)
SATA Version is:  SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Mon Sep  8 19:19:45 2014 EDT
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x00)    Offline data collection activity
                    was never started.
Self-test execution status:      (   0)    The previous self-test routine completed
                    been run.
data collection:         (37980) seconds.
capabilities:              (0x7b) SMART execute Offline immediate.
                    command.
                    Self-test supported.
SMART capabilities:            (0x0003)    Saves SMART data before entering
                    power-saving mode.
Error logging capability:        (0x01)    Error logging supported.
Short self-test routine
recommended polling time:      (   2) minutes.
Extended self-test routine
recommended polling time:      ( 381) minutes.
Conveyance self-test routine
recommended polling time:      (   5) minutes.
SCT capabilities:            (0x703d)    SCT Status supported.
                    SCT Data Table supported.
  1 Raw_Read_Error_Rate     0x002f   200   200   051    Pre-fail  Always       -       20
  3 Spin_Up_Time            0x0027   192   171   021    Pre-fail  Always       -       5375
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       41
  5 Reallocated_Sector_Ct   0x0033   200   200   140    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x002e   200   200   000    Old_age   Always       -       0
  9 Power_On_Hours          0x0032   097   097   000    Old_age   Always       -       2688
10 Spin_Retry_Count        0x0032   100   253   000    Old_age   Always       -       0
11 Calibration_Retry_Count 0x0032   100   253   000    Old_age   Always       -       0
12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       41
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       26
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -       19
194 Temperature_Celsius     0x0022   119   111   000    Old_age   Always       -       31
196 Reallocated_Event_Count 0x0032   200   200   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0032   200   200   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0030   100   253   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x0032   200   200   000    Old_age   Always       -       0
200 Multi_Zone_Error_Rate   0x0008   200   200   000    Old_age   Offline      -       71
SMART Error Log Version: 1
No Errors Logged
# 1  Extended offline    Completed without error       00%      2680         -
# 2  Short offline       Completed without error       00%      2600         -
# 3  Short offline       Completed without error       00%      2362         -
# 4  Extended offline    Completed without error       00%      2274         -
# 5  Short offline       Completed without error       00%      2194         -
# 6  Short offline       Completed without error       00%      2026         -
# 7  Extended offline    Completed without error       00%      1938         -
# 8  Short offline       Completed without error       00%      1859         -
# 9  Short offline       Completed without error       00%      1619         -
#10  Extended offline    Completed without error       00%      1531         -
#11  Short offline       Completed without error       00%      1451         -
#12  Short offline       Completed without error       00%      1283         -
#13  Extended offline    Completed without error       00%      1196         -
#14  Short offline       Completed without error       00%      1115         -
#15  Short offline       Completed without error       00%       899         -
#16  Extended offline    Completed without error       00%       811         -
#17  Short offline       Completed without error       00%       731         -
#18  Extended offline    Completed without error       00%       536         -
#19  Short offline       Completed without error       00%       461         -
#20  Short offline       Completed without error       00%       222         -
#21  Extended offline    Completed without error       00%       135         -
The only difference I see with this drive vs the other 5 in my array is that the Raw Read Error Count is 20, while all the others is still 0.  It says the threshold for this value is 51, so should I not be concerned?
I am running new SMART tests now.
Edit-Short test completed with no errors.
Long test is going, but will take about 6 hours to complete...
