Sorry for replying so late. I've been ill...
I am running freenas under esxi with 4 3TB WD Red drives in passthrough mode and 8GB of RAM assigned to it. Motherboard: ASRock B85M Pro4 CPU: Intel Haswell Core i5 4440S 2.80GHz 6MB Box
( I know, no ECC memory. I only learned of that requirement while looking for a solution for my present problem. I did however run memtest86 for 4 days to see whether memory problems could have caused this. It did not find any memory problems )
Last login: Thu Sep 25 08:50:15 2014 from 192.167.1.10
FreeBSD 9.2-RELEASE-p9 (FREENAS.amd64) #0 r262572+cc525fe: Thu Jul 3 14:22:45 PDT 2014
FreeNAS (c) 2009-2014, The FreeNAS Development Team
All rights reserved.
FreeNAS is released under the modified BSD license.
For more information, documentation, help or support, go here:
http://freenas.org
Welcome to FreeNAS van Jents
Could not chdir to home directory /mnt/Main/jents: No such file or directory
[jents@jentsfreenas] /% dmesg
Copyright (c) 1992-2013 The FreeBSD Project.
Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
The Regents of the University of California. All rights reserved.
FreeBSD is a registered trademark of The FreeBSD Foundation.
FreeBSD 9.2-RELEASE-p9 #0 r262572+cc525fe: Thu Jul 3 14:22:45 PDT 2014
root@build3.ixsystems.com:/fusion/jenkins/9.2.1.6-RELEASE/os-base/amd64/fusion/jenkins/9.2.1.6-RELEASE/FreeBSD/src/sys/FREENAS.amd64 amd64
gcc version 4.2.1 20070831 patched [FreeBSD]
CPU: Intel(R) Core(TM) i5-4440S CPU @ 2.80GHz (2799.19-MHz K8-class CPU)
Origin = "GenuineIntel" Id = 0x306c3 Family = 0x6 Model = 0x3c Stepping = 3
Features=0xfa3fbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,DTS,MMX,FXSR,SSE,SSE2,SS>
Features2=0x9ed83203<SSE3,PCLMULQDQ,SSSE3,FMA,CX16,SSE4.1,SSE4.2,MOVBE,POPCNT,AESNI,XSAVE,OSXSAVE,AVX,HV>
AMD Features=0x28100800<SYSCALL,NX,RDTSCP,LM>
AMD Features2=0x1<LAHF>
TSC: P-state invariant
real memory = 8589934592 (8192 MB)
avail memory = 8227758080 (7846 MB)
Event timer "LAPIC" quality 600
ACPI APIC Table: <PTLTD APIC >
WARNING: VIMAGE (virtualized network stack) is a highly experimental feature.
MADT: Forcing active-low polarity and level trigger for SCI
ioapic0 <Version 1.1> irqs 0-23 on motherboard
kbd1 at kbdmux0
cryptosoft0: <software crypto> on motherboard
aesni0: <AES-CBC,AES-XTS> on motherboard
padlock0: No ACE support.
acpi0: <INTEL 440BX> on motherboard
acpi0: Power Button (fixed)
Timecounter "HPET" frequency 14318180 Hz quality 950
cpu0: <ACPI CPU> on acpi0
attimer0: <AT timer> port 0x40-0x43 irq 0 on acpi0
Timecounter "i8254" frequency 1193182 Hz quality 0
Event timer "i8254" frequency 1193182 Hz quality 100
atrtc0: <AT realtime clock> port 0x70-0x71 irq 8 on acpi0
Event timer "RTC" frequency 32768 Hz quality 0
Timecounter "ACPI-fast" frequency 3579545 Hz quality 900
acpi_timer0: <24-bit timer at 3.579545MHz> port 0x1008-0x100b on acpi0
pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0
pci0: <ACPI PCI bus> on pcib0
pcib1: <ACPI PCI-PCI bridge> at device 1.0 on pci0
pci1: <ACPI PCI bus> on pcib1
isab0: <PCI-ISA bridge> at device 7.0 on pci0
isa0: <ISA bus> on isab0
atapci0: <Intel PIIX4 UDMA33 controller> port 0x1f0-0x1f7,0x3f6,0x170-0x177,0x376,0x1060-0x106f at device 7.1 on pci0
ata0: <ATA channel> at channel 0 on atapci0
ata1: <ATA channel> at channel 1 on atapci0
pci0: <bridge> at device 7.3 (no driver attached)
pci0: <base peripheral> at device 7.7 (no driver attached)
vgapci0: <VGA-compatible display> port 0x1070-0x107f mem 0xec000000-0xefffffff,0xfe000000-0xfe7fffff irq 16 at device 15.0 on pci0
mpt0: <LSILogic 1030 Ultra4 Adapter> port 0x1400-0x14ff mem 0xfeba0000-0xfebbffff,0xfebc0000-0xfebdffff irq 17 at device 16.0 on pci0
mpt0: MPI Version=1.2.0.0
pcib2: <ACPI PCI-PCI bridge> at device 17.0 on pci0
pci2: <ACPI PCI bus> on pcib2
em0: <Intel(R) PRO/1000 Legacy Network Connection 1.0.6> port 0x2000-0x203f mem 0xfd5c0000-0xfd5dffff,0xfdff0000-0xfdffffff irq 18 at device 0.0 on pci2
em0: Ethernet address: 00:0c:29:52:c1:c1
pcib3: <ACPI PCI-PCI bridge> at device 21.0 on pci0
pci3: <ACPI PCI bus> on pcib3
mps0: <LSI SAS2008> port 0x4000-0x40ff mem 0xfd4fc000-0xfd4fffff,0xfd480000-0xfd4bffff irq 18 at device 0.0 on pci3
mps0: Firmware: 15.00.00.00, Driver: 16.00.00.00-fbsd
mps0: IOCCapabilities: 1285c<ScsiTaskFull,DiagTrace,SnapBuf,EEDP,TransRetry,EventReplay,HostDisc>
pcib4: <ACPI PCI-PCI bridge> at device 21.1 on pci0
pci4: <ACPI PCI bus> on pcib4
pcib5: <ACPI PCI-PCI bridge> at device 21.2 on pci0
pci5: <ACPI PCI bus> on pcib5
pcib6: <ACPI PCI-PCI bridge> at device 21.3 on pci0
pci6: <ACPI PCI bus> on pcib6
pcib7: <ACPI PCI-PCI bridge> at device 21.4 on pci0
pci7: <ACPI PCI bus> on pcib7
pcib8: <ACPI PCI-PCI bridge> at device 21.5 on pci0
pci8: <ACPI PCI bus> on pcib8
pcib9: <ACPI PCI-PCI bridge> at device 21.6 on pci0
pci9: <ACPI PCI bus> on pcib9
pcib10: <ACPI PCI-PCI bridge> at device 21.7 on pci0
pci10: <ACPI PCI bus> on pcib10
pcib11: <ACPI PCI-PCI bridge> at device 22.0 on pci0
pci11: <ACPI PCI bus> on pcib11
pcib12: <ACPI PCI-PCI bridge> at device 22.1 on pci0
pci12: <ACPI PCI bus> on pcib12
pcib13: <ACPI PCI-PCI bridge> at device 22.2 on pci0
pci13: <ACPI PCI bus> on pcib13
pcib14: <ACPI PCI-PCI bridge> at device 22.3 on pci0
pci14: <ACPI PCI bus> on pcib14
pcib15: <ACPI PCI-PCI bridge> at device 22.4 on pci0
pci15: <ACPI PCI bus> on pcib15
pcib16: <ACPI PCI-PCI bridge> at device 22.5 on pci0
pci16: <ACPI PCI bus> on pcib16
pcib17: <ACPI PCI-PCI bridge> at device 22.6 on pci0
pci17: <ACPI PCI bus> on pcib17
pcib18: <ACPI PCI-PCI bridge> at device 22.7 on pci0
pci18: <ACPI PCI bus> on pcib18
pcib19: <ACPI PCI-PCI bridge> at device 23.0 on pci0
pci19: <ACPI PCI bus> on pcib19
pcib20: <ACPI PCI-PCI bridge> at device 23.1 on pci0
pci20: <ACPI PCI bus> on pcib20
pcib21: <ACPI PCI-PCI bridge> at device 23.2 on pci0
pci21: <ACPI PCI bus> on pcib21
pcib22: <ACPI PCI-PCI bridge> at device 23.3 on pci0
pci22: <ACPI PCI bus> on pcib22
pcib23: <ACPI PCI-PCI bridge> at device 23.4 on pci0
pci23: <ACPI PCI bus> on pcib23
pcib24: <ACPI PCI-PCI bridge> at device 23.5 on pci0
pci24: <ACPI PCI bus> on pcib24
pcib25: <ACPI PCI-PCI bridge> at device 23.6 on pci0
pci25: <ACPI PCI bus> on pcib25
pcib26: <ACPI PCI-PCI bridge> at device 23.7 on pci0
pci26: <ACPI PCI bus> on pcib26
pcib27: <ACPI PCI-PCI bridge> at device 24.0 on pci0
pci27: <ACPI PCI bus> on pcib27
pcib28: <ACPI PCI-PCI bridge> at device 24.1 on pci0
pci28: <ACPI PCI bus> on pcib28
pcib29: <ACPI PCI-PCI bridge> at device 24.2 on pci0
pci29: <ACPI PCI bus> on pcib29
pcib30: <ACPI PCI-PCI bridge> at device 24.3 on pci0
pci30: <ACPI PCI bus> on pcib30
pcib31: <ACPI PCI-PCI bridge> at device 24.4 on pci0
pci31: <ACPI PCI bus> on pcib31
pcib32: <ACPI PCI-PCI bridge> at device 24.5 on pci0
pci32: <ACPI PCI bus> on pcib32
pcib33: <ACPI PCI-PCI bridge> at device 24.6 on pci0
pci33: <ACPI PCI bus> on pcib33
pcib34: <ACPI PCI-PCI bridge> at device 24.7 on pci0
pci34: <ACPI PCI bus> on pcib34
acpi_acad0: <AC Adapter> on acpi0
atkbdc0: <Keyboard controller (i8042)> port 0x60,0x64 irq 1 on acpi0
atkbd0: <AT Keyboard> irq 1 on atkbdc0
kbd0 at atkbd0
atkbd0: [GIANT-LOCKED]
psm0: <PS/2 Mouse> irq 12 on atkbdc0
psm0: [GIANT-LOCKED]
psm0: model IntelliMouse, device ID 3
uart0: <16550 or compatible> port 0x3f8-0x3ff irq 4 flags 0x10 on acpi0
uart1: <16550 or compatible> port 0x2f8-0x2ff irq 3 on acpi0
fdc0: <floppy drive controller> port 0x3f0-0x3f5,0x3f7 irq 6 drq 2 on acpi0
fd0: <1440-KB 3.5" drive> on fdc0 drive 0
orm0: <ISA Option ROMs> at iomem 0xc0000-0xc7fff,0xca000-0xcafff,0xdc000-0xdffff,0xe0000-0xe7fff on isa0
sc0: <System console> at flags 0x100 on isa0
sc0: VGA <16 virtual consoles, flags=0x300>
vga0: <Generic ISA VGA> at port 0x3c0-0x3df iomem 0xa0000-0xbffff on isa0
wbwd0: HEFRAS and EFER do not align: EFER 0x2e DevID 0x0f DevRev 0x00 CR26 0x4f
acpi_throttle0: <ACPI CPU Throttling> on cpu0
coretemp0: <CPU On-Die Thermal Sensors> on cpu0
coretemp0: Tj(target) value 0 does not seem right.
Timecounters tick every 10.000 msec
ipfw2 (+ipv6) initialized, divert enabled, nat enabled, default to accept, logging disabled
DUMMYNET 0xfffffe00051e1dc0 with IPv6 initialized (100409)
load_dn_sched dn_sched RR loaded
load_dn_sched dn_sched WF2Q+ loaded
load_dn_sched dn_sched FIFO loaded
load_dn_sched dn_sched PRIO loaded
load_dn_sched dn_sched QFQ loaded
da0 at mpt0 bus 0 scbus2 target 0 lun 0
da0: <VMware Virtual disk 1.0> Fixed Direct Access SCSI-2 device
da0: 320.000MB/s transfers (160.000MHz, offset 127, 16bit)
da0: Command Queueing enabled
da0: 8192MB (16777216 512 byte sectors: 255H 63S/T 1044C)
cd0 at ata1 bus 0 scbus1 target 0 lun 0
cd0: <NECVMWar VMware IDE CDR10 1.00> Removable CD-ROM SCSI-0 device
cd0: Serial Number 10000000000000000001
cd0: 33.300MB/s transfers (UDMA2, ATAPI 12bytes, PIO 65534bytes)
cd0: Attempt to query device size failed: NOT READY, Medium not present
da1 at mps0 bus 0 scbus3 target 0 lun 0
da1: <ATA WDC WD30EFRX-68E 0A80> Fixed Direct Access SCSI-6 device
da1: Serial Number WD-WMC4N2318917
da1: 600.000MB/s transfers
da1: Command Queueing enabled
da1: 2861588MB (5860533168 512 byte sectors: 255H 63S/T 364801C)
da1: quirks=0x8<4K>
da2 at mps0 bus 0 scbus3 target 1 lun 0
da2: <ATA WDC WD30EFRX-68E 0A80> Fixed Direct Access SCSI-6 device
da2: Serial Number WD-WMC4N2322882
da2: 600.000MB/s transfers
da2: Command Queueing enabled
da2: 2861588MB (5860533168 512 byte sectors: 255H 63S/T 364801C)
da2: quirks=0x8<4K>
da3 at mps0 bus 0 scbus3 target 2 lun 0
da3: <ATA WDC WD30EFRX-68E 0A80> Fixed Direct Access SCSI-6 device
da3: Serial Number WD-WMC4N2321890
da3: 600.000MB/s transfers
da3: Command Queueing enabled
da3: 2861588MB (5860533168 512 byte sectors: 255H 63S/T 364801C)
da3: quirks=0x8<4K>
da4 at mps0 bus 0 scbus3 target 3 lun 0
da4: <ATA WDC WD30EFRX-68E 0A80> Fixed Direct Access SCSI-6 device
da4: Serial Number WD-WMC4N2334941
da4: 600.000MB/s transfers
da4: Command Queueing enabled
da4: 2861588MB (5860533168 512 byte sectors: 255H 63S/T 364801C)
da4: quirks=0x8<4K>
Timecounter "TSC-low" frequency 1399594000 Hz quality 1000
Trying to mount root from ufs:/dev/ufs/FreeNASs2a [ro]...
GEOM_RAID5: Module loaded, version 1.1.20130907.44 (rev 5c6d2a159411)
GEOM_ELI: Device da1p1.eli created.
GEOM_ELI: Encryption: AES-XTS 256
GEOM_ELI: Crypto: hardware
GEOM_ELI: Device da2p1.eli created.
GEOM_ELI: Device da3p1.eli created.
GEOM_ELI: Device da4p1.eli created.
ZFS filesystem version: 5
ZFS storage pool version: features support (5000)
VMware memory control driver initialized
I do have a backup of almost all of the data on my old NAS. But before I start fresh ( with new ECC  DRAM hardware ), I would really like to know what went wrong.
