Fail event on /dev/md127
ezelbanaan
in code blocks please
1. zpool status -v
2. glabel status
zpool status -v
root@truenas[~]# zpool status -v
  pool: Games
 state: ONLINE
  scan: resilvered 0B in 00:00:02 with 0 errors on Mon Apr  4 15:52:43 2022
        NAME                                    STATE     READ WRITE CKSUM
        Games                                   ONLINE       0     0     0
          612295a2-8d4f-11eb-aea2-b3976b669fd2  ONLINE       0     0     0
          ad43c14a-23c1-11ec-a9ab-589cfc10fff6  ONLINE       0     0     0
errors: No known data errors
  pool: Raid-Z1
 state: ONLINE
  scan: scrub repaired 0B in 00:44:21 with 0 errors on Sun Mar  6 12:44:24 2022
        Raid-Z1                                   ONLINE       0     0     0
          raidz1-0                                ONLINE       0     0     0
            34e64300-873d-11eb-9049-0344185f9b67  ONLINE       0     0     0
            352f2142-873d-11eb-9049-0344185f9b67  ONLINE       0     0     0
            3520fb1f-873d-11eb-9049-0344185f9b67  ONLINE       0     0     0
            35bc0a3e-873d-11eb-9049-0344185f9b67  ONLINE       0     0     0
  pool: boot-pool
 state: ONLINE
  scan: scrub repaired 0B in 00:02:45 with 0 errors on Tue Feb 22 03:47:45 2022
          sda       ONLINE       0     0     0
glabel status
root@truenas[~]# glabel status
zsh: command not found: glabel
I couldn't figure out how to install glabel
NugentS
Good point - missed that.
in reverse.
boot-pool is a single disk - sda - with no issues
Raid-Z1 is a RAIDZ1 array with 4 disks. No issues
Games is a think a stripe of 2 disks. No issues
If I am right about the above then all is I think good (with the disks themselves anyway). You still need to replace the nasty SATA expsnsion card with a proper HBA. However I have no idea about proxmox and what it does so I shall caveat my all is OK with "but proxmox"
NugentS
Hmmm anyone know what has replaced glabel status with on Scale? ie how to reference the GPTID back to the /dev/whatever
ezelbanaan
in reverse.
Ok, thanks for all the help. I will definitely replace the SATA expension card.
Arwen
In Linux, the "/dev/mdXXX" are SOFTWARE RAID. Which a prior output clearly shows it as a 2 way mirror of;
md127 : active raid1 sde1[1] sdd1[0](F)
The "sdd1" disk / partition has failed.
This is almost certainly the SWAP space, as my own VM of TrueNAS SCALE has this;
root@truenas[~]# swapon
NAME      TYPE      SIZE USED PRIO
/dev/dm-0 partition   2G   0B   -2
root@truenas[~]# cryptsetup status /dev/dm-0
/dev/dm-0 is active and is in use.
  type:    PLAIN
  cipher:  aes-cbc-essiv:sha256
  keysize: 256 bits
  key location: dm-crypt
  device:  /dev/md127
  sector size:  512
  offset:  0 sectors
  mode:    read/write
root@truenas[~]# cat /proc/mdstat
Personalities : [linear] [multipath] [raid0] [raid1] [raid6] [raid5] [raid4] [raid10]
md127 : active raid1 sdc1[1] sdb1[0]
      2097088 blocks super non-persistent [2/2] [UU]
unused devices: <none>
These were bogging me too, and I didn't could make any sense out of them.
Looked it up on JIRA and there is already a fix for these "confusing" messages due in SCALE 22.12.1
