I noticed when creating the windows 10 VM my ram went from using 4Gbs to 6Gbs not a big deal. Then when i installed plex on the VM it jumped to 8gbs used still no need for concern. But when I did a test of moving about 10GBs of anime over to the VM from my local machine the RAM went up to 14GBs so I thought it's writing from RAM. so i let the transfer finish got 90 mbs transfer speeds which i was expecting. Using 1gb NIC's on both esxi and freenas, the RAM never came back down it stayed at 14Gbs. I had to reboot the freeNAS box for memory usage to go back to 4Gbs. i did wait roughly 30 minutes before i rebooted to see if it would come down and it did not move. Any help would be greatly appreciated!!
My setup currently is using the freenas as a datastore for my esxi box I'm doing this using iSCSI. Yesterday took me half a day to get that working correctly. My nas is a total of 10TBs usable in raidz-2. I made the iSCSI 5TB. My over all plan was to use 4TBs of that as a Plex server on windows 10 as a VM on esxi. When building my box i knew this was the route i was attempting to take. I found that for iSCSI i should use a SLOG. My issue is i was completely unsure how to add a SLOG and was using a 250GB Samsung evo 840 for this but I'm not sure i set it up right. When I created my pool for raidz-2 i just used the log option and added the ssd as the device for that was that correct?
I'm new to freenas and I bought all my hardware on recommendations from here. My box is a single Xeon e3-1230 on a supermicro X9SCM-F with 16 GBs of unbuffered ECC Ram using a HBA 9207-8i in IT mode powered by a seasonic 750w gold focus PSU.
TDLR- New to freeNAS, eSXI 6.5 using iSCSI for datastore from FreeNAS. Not sure SLOG is setup correctly and seeing high ram on freenas when using VM on ESXi.
