Hi everyone, I apologize if the problem has already been addressed but I have not found any solution the same. My problem is the following, I have 2 virtual machines with Freenas 11.2 and I'm trying to convert them to something that works with virtualbox. The steps I perform are as follows:
- Stop virtual machine;
- dd of zvol virtual machine in raw format;
- I copy the raw file to a linux pc and convert it with vboxmanage in vdi format.
- I create a new virtual machine in virtualbox and I assign it the newly converted disk;
- I start the virtual macvhine and it stops at boot with the message "no bootable disk".
You can help me?
Thank you all
You can help me?
Thank you all
