Expanding Storage pool not working
Orso
Expanding an existing storage pool is a question that has been asked several times and answered several times as well. But. What if it doesnt work?
I have installed TrueNAS Core TrueNAS-13.0-RELEASE for testing. It's runing in a VM with 1 system disk and 8 datadisks.
I've created a nice Storage pool with 2 drives of 10Gib each and has 7.62GiB available. So far so good.
I then added 2 extra drives, also 10Gib each, and have now 4 drives in the storage pool.
everything looks good. No errors.
I tried hitting "Expand Pool" and hit EXPAND POOL but nothing is happening.
No dedupe or anything fancy set up.
???? Thanks :oops:
Bjorn
Orso
Sry. Can't edit my post so i'm adding this:
"By added 2 extra drives", I meant going to Storage / Pools, clicking the Pool, then Status, then the 3-dot menu, Extend, selected 1 free drive and hit the EXTEND button".
You're quoting 2 completely different options there... chances are the second one has landed you in a place you may not want to be (and you would have needed to tick the "Force" option to get there)...
I would suggest posting the output from zpool status -v in code tags so we can confirm that your pool is still configured in a safe state.
Orso
root@truenas[~]# zpool status -v pool: Pool1 state: ONLINE scan: resilvered 14.9M in 00:00:00 with 0 errors on Tue Jun 7 15:10:06 2022 remove: Removal of vdev 1 copied 24K in 0h0m, completed on Tue Jun 7 15:08:06 2022 72 memory used for removed device mappings config: NAME STATE READ WRITE CKSUM Pool1 ONLINE 0 0 0 mirror-0 ONLINE 0 0 0 gptid/912a4ad4-e662-11ec-b197-00155d010a01 ONLINE 0 0 0 gptid/9127af4a-e662-11ec-b197-00155d010a01 ONLINE 0 0 0 gptid/eb5ad3a5-e662-11ec-b197-00155d010a01 ONLINE 0 0 0 gptid/262aba59-e663-11ec-b197-00155d010a01 ONLINE 0 0 0 errors: No known data errors pool: boot-pool state: ONLINE config: NAME STATE READ WRITE CKSUM boot-pool ONLINE 0 0 0 da0p2 ONLINE 0 0 0 errors: No known data errors
Orso
Btw. Dont' waste tons of brain cycles to assist with this particular problem. It's just a trial-setup to learn how disk-stuff works before I work with real data.
I just don't understand what I am doing wrong.
Seems to be a good idea to get a good feeling about how things work :)
Looks like you just have a 4-way mirror now, so no additional capacity.
If you meant to increase capacity, you wanted to add an additional data vdev
