expanding 2 vDev 8 1TB Disks Mirrors
VioletDragon
Hi folks,
I need to expanding my iSCSI array i have 8 Disks 4 Disk each Vdev Im going to be upgrading my Drives to 2TB Drives 4 Disks per Vdev however what is the best way to do this i also have a Zvol for iSCSI Luns to each of my Hypervisors. Can you expand the Zvol or should I just start from scratch ? I should have 4TB Usable when i create 4 Disks per Vdev ? Example of my existing array.
    iSCSI                                           ONLINE       0     0     0
      mirror-0                                      ONLINE       0     0     0
        gptid/7c39221d-ea2c-11e9-b7f4-0017087d2e9a  ONLINE       0     0     0
        gptid/7cea36c6-ea2c-11e9-b7f4-0017087d2e9a  ONLINE       0     0     0
        gptid/470b7803-36c0-11eb-80e1-00074309b09a  ONLINE       0     0     0
        gptid/5efb87b2-2066-11ec-b66d-d4ae5268b175  ONLINE       0     0     0
      mirror-1                                      ONLINE       0     0     0
        gptid/7d87604a-ea2c-11e9-b7f4-0017087d2e9a  ONLINE       0     0     0
        gptid/246d2d3f-8dee-11eb-a6d7-00074309b09a  ONLINE       0     0     0
        gptid/f5b603a3-36d6-11eb-80e1-00074309b09a  ONLINE       0     0     0
        gptid/76424b79-209a-11ec-b66d-d4ae5268b175  ONLINE       0     0     0
Thanks.
Jack.
NugentS
If thats really a 4 way mirror in each vdev (sorry - I have difficulty getting my head around the concept for 1TB HDD, or are they SSD)
I would swap 2 disks in each mirror, resilver and then do the other two disks in each mirror. As mirrors they resilver quite fast.
VioletDragon
4 Disks per Vdev. Is it possible to expand the Zvol as well without loosing all VMs ?
NugentS
I don't know
4 Disks per Vdev
Indeed. Did you intend to have them in four-way mirrors? ZFS allows that, but it's a pretty unusual configuration.
Of course. Edit the zvol and change the size. But whether, and how, your hypervisor(s) will take advantage of the additional space is a question you'd need to address to whatever support channels exist for that hypervisor.
VioletDragon
Reason why i did this is because two vDevs gives me more Storage than just one vDev.
