European Plugs
erledda
Hi, I'm from italy and I'm willing to buy a TrueNas mini x+, we couldn't find any European seller, I'm ok with buying it from the USA, the only issue is the plug since we use type F and C and USA uses type B, there's a way to change the Nas plugs or can someone indicate me a European seller?
As you can see from the image about half way down the page, it uses the international standard "kettle plug", so you will be able to easily swap out for a local cable if you source it from the USA.
Davvo
Patrick M. Hausen
Don't you have a truckload of spare power cords lying around like everyone else? I could send you some. How many do you need? :wink:
Davvo
