ESXi 6.0/FreeNAS 11 iSCSI error
ciscoguru
I'm new to FreeNAS and iSCSI in general. Running FreeNAS 11, I created the iSCSI pieces, and I was able to successfully connect to it from Windows 10 (saw the volume in disk management, didn't format or anything else). When I try to connect to it from my ESXi host, though, I get a warning message that there was a connection error and it is dropping the connection. It shows up in ESXi as dead briefly under the iSCSI software adapter details and then subsequently is gone when I rescan the adapters.
Any thoughts on what I'm doing wrong or what might be happening? MTU is 1500 (my lab network isn't setup for jumbo frames); single interface on my FreeNAS box.
Spearfoot
He of the long foot
Welcome to the forums!
Please post your full system specifications, per the Forum rules.
ciscoguru
Whoops! Sorry about that...it's a Dell PE2950, PERC H200 SAS controller, 2xXeon 3.0GHz dual-core procs, 32GB ram, 4 300GB SAS 15k drives
Spearfoot
He of the long foot
Thankee!
Well, you've got enough memory to proceed... How do you have your disks configured? Are you running the H200 in IT mode?
Forum member @Benjamin Bryan has written an excellent tutorial on setting up a FreeNAS-on-ESXi All-In-One system: "FreeNAS on VMware ESXi 6.0 Guide". You can ignore most of the guide, but it does go in to detail on setting up iSCSI. See part 18: "Create an iSCSI share for VMware".
Good luck!
ciscoguru
Ah! That's great. Yep, I flashed it into IT mode, letting FreeNAS have its way with the disks. I'll check that guide out.
Spearfoot
He of the long foot
You'll probably want to configure your disks as mirrors; this will give the best performance. And you ought to give thought to the idea of installing a ZIL SLOG device, too. The forum has a boatload of discussion on the subject of configuring FreeNAS to provide block storage; search around and you'll find lots of fun reading material! :)
