freejetz888
- May 25, 2016
Hi all, I was bringing my freenas server up this morning when suddenly I hear the fans kick to max speed and got over just in time to see the screen go from the freenas server menu to black with a couple errors on it. I forced a shutdown, brought it back up and everything was ok. Looked through the logs and believe I found the errors that caused the anomaly. To be clear, these errors came in immediately after a full bootup with the freenas console menu visible.
FreeNAS-9.10-STABLE-201605240427 (64fcd8e) running on an IBM x3550 m4 server
CPU: 2 x 2.4 Ghz Intel Xeon 4 core E5-2609
Ram: 32GB 1.35volt 1066Mhz
All components IBM
Any thoughts of the possible cause would be appreciated.
Jun 7 08:35:42 freenas2 ipmi0: KCS: Reply address mismatch Jun 7 08:35:54 freenas2 ipmi0: KCS Error Data ff Jun 7 08:36:01 freenas2 ugen1.3: <no manufacturer> at usbus1 (disconnected) Jun 7 08:36:01 freenas2 uhub4: at uhub3, port 1, addr 3 (disconnected) Jun 7 08:36:01 freenas2 ugen1.4: <IBM> at usbus1 (disconnected) Jun 7 08:36:01 freenas2 urndis0: at uhub4, port 5, addr 4 (disconnected) Jun 7 08:36:12 freenas2 ipmi0: KCS Error Data ff Jun 7 08:36:18 freenas2 ipmi0: KCS: Error retry exhausted Jun 7 08:36:24 freenas2 ipmexi0: KCS: Failed to start write
All components IBM
