error: unable to upgrade connection: container not found ("xyz")
indivision
Hello.
After upgrading from 22.12.0 to 22.12.1 all of my apps that use mounted storage fail to deploy. They give this error in the shell:
From what I've read, this can be a symptom of using an SMB share as a mount path. However, I thought that issue applied to 22.12.0 also? My setup worked fine with that version and only has this issue with the latest version.
Maybe I'm not understanding the path restriction correctly. I am not using the same mount path as a share. But, I am using sub-directories within a share as the mount paths. Is that not allowed as well?
Or, is there some other fix for this that I'm missing?
On another note, I'm seeing that NFS shares are preferred for mounted storage. I could convert everything to that. But, would I then be unable to mount those folders in Windows? It's pretty useful to be able to manipulate the files in a Windows environment from time to time...
Thank you for any help anyone can offer.
